What is your Heart Rate range?
I just go from what my garmin watch tells me :slight_smile:
I dont actually know how it determins the resting heart rate? It doesn’t simply take the lowest recorded value as there have been plenty of times I can see that my HR has dropped lower than what my watch has determined is my resting HR.
I have a Samsung smartwatch, it says my resting heart rate is 60-65 but at night I see my heart rate go much lower. I haven’t been able to find an actual definition of rhr
M52
Resting:46
Max:186
Male
Resting: 42
Max: 175 cycling / 182 running
What do you use for resting heart rate, lowest heart rate during sleep?
I do wonder about that. For last night my lowest bpm was 44 but garmin reports an average over a period I think which is 48bpm :exploding_head:
Like a lot of heart rate and performance stats - the definitions can be a bit fuzzy.
I believe resting heart rate should be taken when fully rested and inactive but awake.
It seems that my garmin usually uses values from after my alarm goes off but before I get my ass out of bed or when i’m sat on the sofa at night watching TV.
If I just spung out of bed and was active all day I dont know what it would do?
I think the sensor on a watch is perfectly fine accuracy wise for resting heart rate measurements - it’s during activities when they are moving around on the wrist that they can be a bit ropey.
My Garmin was showing me a HR of 280 before the start of parkrun the other week. Though that was because my strap was running out of battery and had gone haywire. But I can count it right?
But playing along with others:
Age 40
RHR: 56 (or so)
Max: 202 (or so)
Range: 146
However thats also a bit misleading as for exercise purposes I am realisically limited to around the 95bpm range as a starting point and that doesnt last long. If I even look at a recovery ride it starts out in the 90s and then jumps up to over 100 pretty readily. So working range is more like 100bpm or something like that. The only physical activity I can do where it doesnt go above 100 (all the time) is yoga.
When I started training consistently, yes, I saw a drop in my RHR for sure but never an increase in Max I don’t think. I have been consistently training (12-15hr weeks) for last 2+ years and my RHR has been stable (bar illness or fatigue) in that period.
Age 53
RHR 41 (average for past month while sleeping, as reported by HRV4 Training using Oura data)
Max HR 196 (last year)
HRR 155
What’s your Vo2 Max?
Mine is apparently 60 for cycling and 56 for running - this is just what Garmin says though so to be taken with a grain of salt.
61
Resting 52
Max 162
HRR is absolutely an indicator. You’re using it wrong if you’re tying to compare individuals. It’s a personalized metric. It can be used with other metrics to paint a picture.
Exactly. Sure monitor your own data over time, but no use in comparing it to others. Unless maybe you want to compare overall long-term trends in relative terms, but not in absolute numbers.
Same here. I’m in the low 60’s. It’s genetic. It is what it is as they say.
age 53
Resting around 60
Max 172
Range 112
LTHR 156 (it’s really obvious, I can hold 156 no problem, but at 157 on a climb, I can feel it almost immediately…2021 was at 154 same deal, knew as soon as I went over. Might need to work on that.
My resting hr is variable and very dependent on how I sleep, and I have sleep issues that I’m working on. But I’ve seen low 50s a couple times in the last 6 months, and high 50s is easy after a good sleep. Good news is that I was put on beta blockers 10 years ago to bring my 80+ resting HR down, and I stopped taking them 18 months ago, so I’m happy with 60 without meds.
Age 35
Resting HR 35-40
Max 195
HRR 155-160
we have to be careful in what we’re talking about in mentioning fitness. I was mentioning fitness in a metabolic sense, not a performance sense.
It’s entirely possible your power at any VO2 utilization has increased without any increase in VO2 utilization. You became more efficient.
But if you have a broadening of heart rate reserve, I would bet you’ll see an increase in VO2max. Which should lead to an absolute increase in fitness (raising the roof). Not necessarily an increase in power at the same VO2 utilization.
Resting: 42
Max: 196
HRR: 154
Garmin vo2 max: currently 63. Was 70 max last season.
Currently 3.96wkg 284w. Was 4.11 last season at 276w or so.
