Riding slow does NOT makes you faster. It makes you slower.
You should only wear a kit when mountain biking if you are in a race.
It doesn’t matter if you stop during a ride on the trainer.
TrainerRoad should be two words.
Matej Mohorič has entered the chat.
Bicycles are mechanical wonders. Components that require batteries to perform their primary functions have no place on a bike.
Here are mine
Wide handlebars belong on road bikes
Downtube shifters and disc brakes are a match made in heaven
KoolAide is great ride fuel
Gitane should be pronounced with a hard “G”
Specialized is an ironic name
The more bags there are on a bike, the better the rider
Power meters have ruined cycling
Pie plates look awesome on a road bike
Hydraulic disc brakes are no better than good cable operated disc brakes
40mm should be the minimum tire width in the pro peloton
There are more…
Disc brakes don’t provide more braking power than rim brakes. They can equally throw you over the bars.
Zone 2, LTT and ISM do not need discussing on EVERY SINGLE THREAD.
Group riding on the road is a waste of training time, and only exists because long solo road rides are mind-numbingly boring.
Pedalling on the spot indoors isn’t cycling. And people that ‘only ride indoors’ aren’t cyclists.
Riding indoors is just a fitness exercise thats relatively useful for actual cycling. Real cycling is a method of transport that takes you from A to B (and often back) outdoors.
I like your first point a lot. Riding easy when you’re supposed to will make you faster in the long run, but just riding “slowly” is too vague. Actual endurance riding in zone 2 isn’t necessarily slow - it’s just very consistent. For example, I ride zone 2 around 220-240 watts outside. That is not slow. It is pretty much impossible to maintain on anything but open roads.
Saddle Bag > Handlebar Bag
There is no such thing as a “beautiful” groupset
Decaf coffee is superior to other coffees.
If you don’t wax your chain you’re not a cyclist.
8x3 gearing is all you really need.
Green bananas > ripe bananas
Sweet spot training is pointless.
Top Tube bag > saddle bag.
You can’t really wax 12s chains or rather it gets expensive quickly but then again you only do 3x8…
There’s nothing wrong with wearing briefs under your cycling shorts / bibs.
In bike shop the other day and was asking owner options for some extra climbing gears for my bike and owner said “you just need get stronger”
Have you tried not sucking?
Sounds like you want to use your gravel bike as your road bike
That was basically the message. lol
There is no such thing as Long, slow distance…it is long, steady distance. Speed is irrelevant.
It is pronounced “mah-VEEK”
It is spelled “Campag”
E-bikes are awesome.
