Trusting the input vs forcing the progression
Grüß Gott aus Deutschland, (hi)
I see two options when I train:
  1. I can trust the input. So, if I approach an interval training, I’d look up what I am supposed to do based on the stimulus. For example, I could ride 6x3min @90% max HR, 2 min rest. I’d then trust this input to be a stimulus and basically lay back and let my body figure out the adaptation and come back faster the next time (if equally well rested).
  2. Or, I could force the progression. Then I’d, for example, look at the total work that I performed the previous session and increase it by 1-2% even if it means that I have to push some intervals above 90%.
I try to figure out how to balance both approaches, since I think both are important aspects of training:
  1. You should aim for the specific stimulus you are after.
  2. You should progressively overload.
I try the following:
  1. I start with (1). I figure out what I am after and then adhere to the lower end to the prescribed stimulus that should be enough to elicit adaptations.
  2. Then, for a while, I increase my output in small increments.
When I feel that I am leaving the stimulus, meaning that I start to overshoot (better would be to assess before that point…), I re-assess by performance reverting back to the starting point. If my training worked, I’d be able to increase my performance with the same input.
What are your thoughts about that?
That’s a lot of overthinking. I’d save the mental gymnastics and FTFP.
Relax mate. Unless you have the time/capacity to increase your volume significantly (and safely). Worrying about 1-2% on a workout will do nothing.
I’d like to refer to this post: Using 3, 5 or 10 minute power to guide intervals - #22 by sfast
In short: If I invest the time anyway, I like to perfect what I do, whatever I do. It is an existential decision on how I live my life.
Of course you ‘force it’.
You always try to improve. Whatever HR or Power target or target % you are using, at the end of the day it’s just a guide. If you can do more (either harder or longer), you do more as long as it feels manageable from a recovery perspective.
Another: can’t see the forest because there are too many trees.
But I want to go to Verona
Sfast, there is no perfect interval. You are missing the forest through the trees.
What is the difference between an interval and one that is 1% harder? Nothing!
There are two opposite approaches:
  • Minimum Effective Dose (MED) – do least possible effort that still triggers adaptations. This is safe bet that facilitates long term consistency and leaves room for longer progression before hitting plateau.
  • Maximum Recoverable Volume (MRV) – do as much as possible that you still can recover for next hard session. This is very personal, and you can burn out multiple times before discovering your limits. You may think that by approaching cautiously you can find your limits safely. Not really, it may take couple months and once you are so deep in hole, it can take very long time to get back.
TR AT + RL/GL can help you with both approaches by tuning AT balance between conservative ↔ aggressive.
But as @AJS914 says, 1% is nothing. You are very likely in better place by keeping interval as prescribed and consuming more calories and/or sleeping 30min more :slight_smile:
