TrainNow is recommending wildly different workout levels
TrainNow has recently been recommending workouts way above my current progression levels. Has anyone else experienced this?
My current anaerobic is a level 1.0, and the other day the suggested workout was Osceola, a 9.5 anaerobic level. When I refreshed the suggested workouts, it would bounce between workouts of a level 9-10, and occasionally a workout of 1.5 would show up.
When I reached out to support, their response was that TrainNow was working as intended, and that I should just give it a try. But these aren’t “stretch” workouts, they are actually marked as “Not Recommended”.
Today, it is suggesting either Paniau (1.5), or d’Aujour (7.6) on refresh. Assuming that I can actually complete the harder workout, why would it suggest two completely different workout levels for the same day? Can anyone explain the logic behind this?
Thanks!
First suggested workout:
Suggested workout after refresh:
I think something has recently changed w/ TrainNow. My wife has been seeing some similar options. It used to offer mostly achievable or productive options and now there’s a lot of stretch or higher.
I got a recommendation that was Breakthrough (though that was NOT apparent during the selection process) and it ended in failure. I knew I was in trouble after the first of three sets, and upon research during the recovery, discovered this was essentially a monster hiding in plain sight.
There is some discussion about this aspect and other changes in another TN topic that I don’t have time to find right now. But from that, TR suggested giving the TN offerings a shot so I took it as assigned.
Based on that mess, I will no longer trust TN without first diving deeper… which partly defeats the purpose of the tool and makes it even less appealing than the other changes that were covered. As of now, I am manually picking workouts until they fix the previously handy TN tool. :frowning:
Agreed 100% its definitely been messed up. I no longer use or trust TN anymore after the recent change.
Mine has started to do similar. I believe it was working as intended until today or very recently.
It isn’t offering wildly different workouts but huge PL jumps.
:hot_face: :hot_face: :hot_face:
Maybe I can complete it… only one way to find out… but think I’ll pass and listen to the workouts area:
Something seriously wrong - particularly the ‘attacking’ suggestions for it seems. I have an anaerobic PL of 1.0, and it will go from suggesting a workout with PL 6.5, down to a PL of 1.5 and then back up again when I hit refresh… both can’t be right.
I’m also getting random suggestions for Attacking - I suspect based on the above and my own TrainNow that it is making a stab at what you might be able to achieve in zones where your PL is currently 1.0 or otherwise v low (so reasonable to suppose you can probably do a bit better than that) - but it does seem a big jump, I am seeing 6.7 Anaerobic and stuff.
My VO2 PL is currently at 4.8 so it is a good bet that I can do better than 1.0 (or 1.5 or whatever it would start you at otherwise) in Anaerobic, but if it were me I’d have started at PL 3 or 4, not 6 or 7… which is higher than my VO2 PL or any future VO2 workouts in my current plan phase… Seems a bit like going off the deep end!
For zones where my PLs are better dialled in (i.e., the ones I am currently training), the recommendations look more sensible/achievable - although I am still getting a Stretch climbing sweetspot one, potentially as I did a hard Zwift race yesterday and it doesn’t want to give me a Threshold one, and my Sweetspot PL is a bit low w.r.t. my Threshold as I haven’t been doing Sweetspot workouts.
I, for one, am actually happy with those “wild” suggestions. To me it feels it now considers individual per zone base PL that I can start from without progressing first into it.
For example: from past experience I already know it doesn’t matter where my current VO2max or anaerobic PLs are, I can directly jump to VO2max PL5.2 or anaerobic PL7.0 workouts to feel challenged. Anything below that is simply waste of time trying to convince Adaptive Training engine.
My hope is for something new :stuck_out_tongue:
I mentioned this is the other TrainNow thread, but for endurance I’m only getting one suggestion and that is pioneer -3.
Me too actually, in Endurance anyway. That happens to be progressive for me so I assumed that was intentional.
I mean so am I in general, I don’t think there is much point doing a PL 1.5 Anaerobic workout when my Anaerobic PL is 1.0 just because I haven’t trained it recently (and my VO2 is 5 or something).
But there’s a difference between suggesting a PL that it thinks might be achievable based on your other zones and jumping right to the top end - if my VO2 PL is 5 and my Anaerobic is 1.0, I think based on logic going in with 3 or 4 is pretty sensible. I would definitely not choose one at 7 or 8!
It’s literally recommending workouts that are marked “not recommended” in the library for me.
This is exactly what I wanted to point out.
To expand example above: let’s say my anaerobic PL is 1.0 and I plan to spend 3 weeks improving it, 2 hard workouts per week i.e. total 6 anaerobic workouts. If I keep doing only “productive” or “stretch” workouts, every time answering “moderate” to survey, I end up with anaerobic PL ~ 7-9. Problem is, due my individual abilities, only 2 of those 6 workouts will be actually productive, 4 first ones are wasted convincing AT.
Now, if TN actually suggests immediately PL7.0 workout (again, personal floor PL for me), then I can actually have all those workouts in productive range, no matter what current PL says.
EDIT: I am not saying TN isn’t buggy right now. Instead, I am hoping that this is new feature that considers personal power curve when suggesting stuff outside your current PL.
I don’t think doing that (jumping right in at PL7-8) is going to be achievable for most people unless their other PLs are also in that kind of range - in which case I do think TrainNow could be making an educated guess at what your PL should/could be in that zone - i.e., if your threshold and VO2 PLs are both like 8.0 then it’s probably reasonable that you might start Anaerobic at 6 or 7.
Which I guess is what you are saying really - I’ve no problem with TN recommending stuff at higher PLs if it thinks those might be achievable based on your other PLs.
The thing here is that doesn’t seem to be the case - i.e., my current VO2 PL is 4.8 (to be precise) and it is recommending me Anaerobic workouts at PL 7.0 (Walden at 7.0 just came up for example) - I don’t think there’s anything in my training history to suggest that might be achievable for me and looking at it, I can see immediately that I would fail it. And to your edit on power curves - sprint and anaerobic has always been a weak spot of mine so I don’t think that supports it either (the power curve comparisons on intervals.icu for example clearly show that I am weaker at the top end).
Which chimes with the other experiences above from e.g., Chad - the workouts it’s suggesting are not just optimistic, they seem to be coming out of thin air.
Then sometimes it is bouncing between anaerobic PL1.5 and anaerobic PL7.0 when I refresh it, which makes even less sense.
True, I can’t argue one way or another. It might be coincidental that TN has buggy suggestions that happen to be in same range I consider “challenging but doable” but it might be not the case for somebody else.
I’m glad I’m not the only one thinking this behavior is odd. It’s unfortunate that I can no longer trust this feature. I might be willing to give one of the max level suggestions a try, even if it looks obviously above my capabilities. But there is still no explanation as to why it would suggest an easy level, and max-hard level, on the same day. Which one am I meant to choose?
I’m also really disappointed in support, as they refuse to answer that question, and just keep copy-pasting the same generic reply that “everything is working correctly”.
Oddly, TN behaves apparently correct in my case, as in that it proposes very reasonable workouts.
It is actually a key difference to wahoo’s Systm where you have to browse through the whole library manually.
Hope they figure it out quickly for those affected.
I’ve been seeing this as well. I seem to ONLY get recommend “not-recommended” workouts.
I reached out to TR support who says this is expected but it feels insane. There’s just no way I can complete any of the workouts I’ve been recommended and don’t really want to waste time failing them
If this is ‘expected behaviour’ then it feels like it undermines the whole Train Now feature in my view… if I can get a recommended anaerobic workout of PL 6.5, refresh, and then see instead an anaerobic workout of PL 1.5, I just don’t see how both of these can be “selections {are} automatically chosen just for you, based on your recent training history” as the blurb at the top of the pages alleges.
There’s two parts to this:
  1. After shuffling workouts, TrainNow can recommend big differences in Workout Levels (this is an issue :frowning_face:)
  2. TrainNow can recommend big jumps in Workout Levels (this is working as intended)
For #1, there’s an issue with the shuffle button that we’re looking into. Thanks for reporting this — I’ll report back when we’re back in action.
For #2, we updated TrainNow to use a machine-learning model to recommend workouts. Probably best to reference Nate’s post for details (linked above), but the TLDR is TrainNow is using a new machine-learning workout recommendation engine that the data shows will more accurately predict workouts that you’re capable of, regardless of your current PL.
Thanks for the update, will pluck up the courage to try out some big PL jumps soon :+1:
