The Triathlon & Ironman Training Thread 2026
That is a good point, its a pain switching between the two, carbs /water, how do you handle electrolytes thought in your bottles?
The common recommendation is to separate them Carbs/water (electrolytes), and I’m not carrying enough bottles to do that without on concentrated carbs.
FWIW i’m referencing my long ride system rather than distinct triathlon advice, though I don’t think it changes things much.
Re: electrolytes - i’m not qualified to give good advice because I just wing it. If its hot out, I throw more sodium citrate in my carb bottles, if its cold out, I do less. its all based on sweating. I’ve also done exactly 0 sweat tests and eye ball the amount that goes in the bottles…
For the marathons I run, I put a bunch of these salt chews in a little baggy and pop a few every so often on the back half.
I think for triathlon the general consensus is cramping on the run is an indication of going to hard on the bike and no amount of sodium is going to save you.
Cramping in general is going hard than what you trained for. You are correct, in that situation, going to hard, no amounts of salts are going to help.
In a tri is is different from a standalone swim, bike or run but the basics are the same but you need to adapt from there imo. Especially if looking to top 10 or podium.
I am currently training for 5-6 x 25-36kms trail running race for next year. I did my first one recently and i am hooked. Like many of you i dont want to give up cycling, i do 50/50 riding/running and left is filled with strength training. I am low volume athlete and will remain so for next year. I am bumping my volume with 20-30%, but still in lower spectrum of the volume. I read here and there about 9:1 min run/walk method and i wanted to know if that is advisable to use it on runs 40-60 mins long, to ease a bit fatigue for next sessions and from previous sessions of running/cycling. As i am not training for IM nor i intent to do for now, cant think of anyone more knowledgeable than triathletes.Hard training on the bike and only easy running is worked well for me and my goals. How do you guys manage the fatigue from all the cycling and running?
@Eushev24 I injured my leg two months ago and started using the 9/1 run/walk when I resumed. It’s been a game changer for me. Before I was doing one tempo run per week and my legs were knackered for two days afterwards to the point where I took the next day off and usually failed any threshold or VO2 workout two days later.
Once starting the 9/1 on my long runs, I’m now running 2-3 days per week. My long runs are 55+ minutes (where I do the 9/1 run/walk) and two shorter runs in the 20-40 minute range. These I run continuously but at Jack Daniels E Pace … 75-83% of threshold pace. It’s relatively easy but my primary focus is building time on my feet and strengthening joints, ligaments, and stabilizing muscles. Most of my cardio gains come from the bike. Also, since doing the 9/1 run/walk I can pass threshold and VO2 workouts a day or two after my long run.
Thanks for insightful reply. I have lingering injury and what helped me was running more often not harder or longer. I will implement 9/1 run/walk to see if I will have better legs for intensity days on the bike. Easy running for me for durability and fitness lie you comes from cycling. I do trial runs and sometimes downhill really impact me. I should try to run on more flat-ish terrain. Good job on the progress of running. Keep ou the good work. Do you do any strength training, I do bodyweight training and that’s another stress for my legs.
@Eushev24 i lift upper body a couple of times per week and, as long as I do not have bike intervals the next day, will do body weight squats, single leg reverse lunges, step ups, and calf raises. I always do core. I’m getting too old not to do these things. :rofl:
I do single leg death lift, squats, Bulgarian splits, lunges or bridges whatever I feel I like to do. Nothing too hard either to save my legs for the runs and rides. I have graduated physical therapy 12 years ago, worked a bit, but found career in other sector (much better paid). I manage my injuries. Recently found that my right ankle has really low mobility compared to left one. Simple knee to the wall stretch difference is like 2-3cm or 20-24 degrees! Wow I started to work on that, surely it’s correlated to my knee problems.
Hey all, been away from training/covid/social media for a bit.
Kona was epic, and inspiring as always even to a fading triathlete such as myself. Nice to see so many pros use my strategy and completely fall apart on the run!
I’d be interested in the communities thoughts on the Kona/TR stats and statements in the latest cast, second third onwards
Training volume and performance numbers sound remarkably low
Kona was incredible, I watched the whole thing from start to finish. An eight-hour race had no right being that exciting. I also enjoyed Jan Frodeno’s interview of Mark Allen in his Going Mental podcast; I love his mindfulness and mindset:
I’m in the middle of my second block of triathlon base training (via TR). It prescribed a 50 min easy run yesterday, which I did in the evening. Even though I felt good during the run and kept it easy, I didn’t recover well and ended up switching this morning’s tempo interval workout to an easy endurance / recovery ride. Legs still feel like lead.
For those that do double days like this - run the evening before a ride - what do you do to recover (other than additional sleep)?
I do a 9/1 run/walk for my long runs. Wondering if I should do the same for these longer(ish) base runs.
Looking back at my training this is the first time I attempted an interval ride the morning after an evening run … maybe I should avoid those whenever possible.
Thoughts?
Yeah, that. I’m also happy to move things around on the calendar; if, for example, I have hard run intervals on Wednesday, tempo ride on Thursday, endurance ride on Friday, and sweet spot ride on Saturday, I might swap the endurance ride on Thursday, even if it means I now have two harder bike workouts on consecutive days. My legs seem to handle two harder bike days back-to-back better than a hard bike day after a hard run day.
Another question: Has anyone done both TR and FasCat (CoachCat) tri plans? How do they compare? Any preference?
Shouldn’t do after an easy run, so maybe shorten that and slow down. The walk breaks are a good idea, you want to be running well when you’re running.
In season, Tuesday nights are group run nights for me so I’d never schedule a hard bike the next morning. I’ve often done them Tuesday morning though, a big breakfast helps.
I am with Joe on this one, if the legs are like lead after an easy run after sleep (I am assuming sleep was not interrupted) the run was too fast or long or a combination of both.
The only other explanation IMO is not getting enough protein and carbs after the session and being depleted into the bike the next day.
What was the pace like verse your 5 or 10km pace? What was your HR verses HRmax?
Was it a hilly run with some steep down hills? Down hill running, which feels easy will generally make the leg more sore than you would think because of the eccentric loading of the muscles.
There should be no problem with an easy run and intervals the next morning (run intervals and bike intervals is a different matter, if that comes up on schedule you need to move things around.)
Related side tangent, if you need to schedule back to back ‘quality sessions’ do the bike session first, fuel and run later.
