The failed-workout survey is terrible
I genuinely don’t understand how I’m supposed to answer it.
I failed Margaret because my legs couldn’t keep turning the pedals. But why?
Intensity? Sure, if the intensity had been 10 times lower, I would’ve finished. You could say that about literally any failed workout.
Training Fatigue? Maybe. Was I fully recovered? No idea.
Nutrition? Sleep? Possibly. How am I supposed to know how much each component contributed failure?
I usually end up selecting Stress/Motivation, simply because I don’t know the answer.
The problem is that you’re asking athletes to diagnose the cause of failure when they often have no way of knowing it.
Why not ask what actually happened and allow “I don’t know” for the cause?
If these answers influence Adaptive Training, aren’t you just feeding it unreliable guesses?
I think it might help to consider how you felt coming into the workout.
Were you tired? If so, did you sleep poorly the night before, or have you been generally tired recently?
Did you feel ready for the workout, or were you nervous about taking it on?
If you came in ready to go and simply couldn’t hit the power targets, then I’d say that intensity was the issue.
If you came in not feeling 100% that could be a sleep or training fatigue issue.
If you just mentally weren’t feeling it, then that sounds like stress/motivation.
If you hadn’t eaten enough or prepared nutritionally before/during the workout, then I’d say that’s a nutrition problem..
Let me know if this helps..
I never have any problem pinpointing the cause. It sometimes hurts to admit it to myself though.
If mye life have given me a lot of stressors, or if sleep have been of bad quality the answer is given.
Nutrition. This is kind of obvious for me. If mye legs give out before they should and not due to sleep or stress it is Nutrition.
Intensity. When the plan recently have given me a ftp bump and the legs give out this is the cause.
If i have two “nutrition” cases after eachother I have to consider if training intensity was the real culprit and i might go back an change the entry for the first one to intensity. Can be changed for up to a week i believe.
This, pretty much
the most common one for me is time, as i do most of these before work and thats a hard limit on when i have to be done. HOWEVER, the cause of time issues is varied. was i overtired and failed to get moving in the morning because not enough sleep? stress from work leave me stuck in transition on the couch when I’m putting shoes on? was i doing housework first and ran into a true time crunch?
I’d try not to over think things. If you were fueling like you usually do, didn’t have abnormally poor sleep, not particularly fatigued going into the training, not unmotivated or stress outside of training, then I’d imagine it’s fatigue. If you can answer yes, to any of those things, then I’d think that’s the cause, and there’s room for improvement leading into your training.
“Terrible” wowsa. idk about that.
Vague sure - but to help with some of your “no idea” or “maybe”…
Fatigue… I know when I am putting on my shoes and squating on one leg if my quad is burning after just 2sec… this might not be good way to start the workout… uh oh… THAT IS FATIGUE for sure. lol Did the warmup feel a bit hard? Fatigued. Concerned your power meter is wrong during hard (or heck even the easy) part of warmup? Fatigued (BUT… see sleep and nutrition as well!.. if you slept 4hrs the last few days or are playing with intermittent fasting and calorie reduction… lol might be Sleep/Nutrition!!!)
Sleep… most people are aware of if tehy have had crap sleep the last few days / week…?! right?
Nutrition… most athletes are usually aware of their carb & food intake over the past 4hrs leading up to workout.. also the day of… and the last 36 some hours. if not… then i would prioritize fueling and keeping an eye on not showing up in a calorie deficit, after a skipped lunch, etc.
Intensity is sort of the last straw… not much hard workouts lately, going up stairs doesn’t burn quads/glutes, not feeling faded going into workout, ate lots of food/carbs, slept normal/good… but this was a scary new/hard looking workout…or new FTP coupled with a hard workout… and proved to be that!
