Another new release from Garmin! Edge Explore 3 announced too.
>max torque: 55nm
Kudos to them for listing it, but that seems awfully low.
IDK. I guess that depends on where it’s measured. If it’s at the flywheel, then it needs to be multiplied by the internal belt drive ratio to get the torque at the freehub. I think more informative is the max Watts and max incline spex, 2200W and 20%, which is way more than enough for me.
There is no belt in the Neo trainers but there is in others, and believe there is in this Nera trainer.
I had a Tacx Neo 1 with a spec’d max torque of 85nm, presumably the same methodology (though cf other discussion about belt vs no) and I could make that thing slip all the time with not exactly thermonuclear max power numbers (say, 1100w sprint/300w 20min). Not at sustained power, to be sure, but any reasonably purposeful dig to catch a wheel or changes in gradient in Zwift, etc. (not to mention high-cadence spin-ups at quite moderate power, though I think that’s not actually a torque limitation.). If all you do is erg mode in TR, I could see it being less of an issue.
So why exactly would someone purchase this vs a neo or kickr? I don’t really understand the need for a new model that is so similar.
WiFi? And side to side movement. Kind of looks to replace the Neo. And maybe you don’t like Wahoo? It’s more accurate than the Kickr Core and has a higher max power so there’s that.
