Tacx Neo vs. Stages power meter 20 watt difference?
Do your pedals or trainer allow the power to be adjusted so that it matches the other device?
In that situation I’d be tempted to just bring my Assiomas along (either once to compare or every time).
Question from 2 years ago - I imagine he figured it out by now. :slight_smile:
Honestly I need to stop being lazy and change the pedals over when I ride the trainer. That way I have 1 number to work from, it’s either that or do 2 separate ftp tests which doesn’t sound fun either :joy:
Hey @ChefAcB! Thanks for the ping :slight_smile:
Unfortunately, in this case scenario, there is no good way to breach the power gap between your Tacx NEO 2T and your Garmin Rally XC200 since you won’t be using your pedals indoors.
However, the good news is that a 4-7 watt difference is actually not that bad and shouldn’t affect your ability to progress through your training or your AI FTP Detection since it uses a broad set of data points.
Ideally, you would use your Garmin Rally XC200 indoors with PowerMatch to bridge that offset and get the same power reading indoors as outdoors, BUT I personally wouldn’t change the pedals every ride, either! Seems like a pain and not worth it, especially if you have everything set up to just hop on. :tipping_hand_woman: So I’d say relax and ride on!
Thanks for the reply!
I’m going to change the pedals regardless so I have 1 number to set my training zones. Worst case scenario if my pedals stop working, I can easily drop the ftp.
It doesn’t seem like a big difference but for those suprathreshold workouts it’s definitely harder than it should be. Either way, I have nothing but positive things to say about using TrainerRoad.
Sounds like a plan @ChefAcB !
Thank you for the good vibes too :slightly_smiling_face: Feel free to ping me again if have any other questions! Definitely gave me a warm welcome from you into the TR Forum.
