Switching to rollers - and why you should try too
I mean a larger platform on both sides in case you need to bail out. I have “crashed” once on rollers but was able to catch myself and didn’t fall. So far my exercise step works pretty well.
I think the whole “need to elevate the front wheel” idea comes from wheel-on trainers. Due to the need of lifting the rear wheel up to make it work, the front wheel ends up being lower than on a normal road. So then you could put a block underneath to make it feel level again. With direct drive trainers, the rear axle can be any height in principle, and at least mine has it the same as the wheel would (roughly, because tyre size varies). Which means there is no real need to elevate the front wheel. Rollers obviously have the wheels level as normal.
I actually figured out years ago that the highest setting on my riser block was more comfortable than ‘level’ when riding a trainer. Then I got a Kicker and just used the 24" wheel setting instead of a riser block.
You’re smarter than me. I knew nothing about indoor cycling so ordered a kickr and kickr climb which I keep in the most elevated position most of the time :rofl:
I described above why I´d need it.
I got Elite rollers in 2013 and when it was snowing here and I training for Flanders I got quite good at them (well for me at least). I found them quite good for 20mins test and I could be on them for an hour plus. Roll on 5 years from that and my balance wasn’t the best and I probably couldn’t have lasted 5mins. I found out a year later it was a chronic iron shortage caused by a bowel (colon) cancer. In researching before the subsequent chemo I was advised that roller are better than a turbo for preserving balance, and I saw a good deal on Elite resistance rollers, so I bought some. I used them a little at first but fortunately it was a good summer and I was out more. Roll on another 5 years I think my balance (on a bike at least) is back so I might try rollers again.
Thinking about it. A direct drive trainer would be the lifting equivalent of machines, cycling would be equivalent to free weights and rollers to gymnastic rings where every imbalance is amplified
Just to add a few things I noticed after using rollers for the first time this winter.
  • The balance is increasing, for sure. It seems silly, but being able to use your right or left hand to the water bottle while riding in a fast peloton is an asset. I trained this during winter.
  • I feel that my pedal skills are more rounded, I don’t know how to explain it, but my pedal stroke feels more natural and better.
  • my coasting time is very low as I got used to pedalling every second. I had a very low coasting time anyway, but now it seems even lower and natural.
I’ve never had a l/r balanced better than 47/53 and even went as bad as 38/62 last year, currently it was around 45/55 but look at my rides on the rollers :smiley:
If I’m contemplating rollers, what are the best-quality options I should consider, that will work well for years and stay with me as I grow stronger?
I currently only ride bikes with 29" wheels, so huge adjustability is not a concern. I’m just thinking of quality in build, features, smoothness, and whatever else I haven’t thought of.
Thanks!
These 2 in the video below look really nice but are only available in the US and Canada. I am happy with my Elite Nero but don’t know how long it will last but it is only a fraction of the price if you look around (I payed less than 500 euro including delivery) and available in Europe.
If ‘bikes with 29" wheels’ includes MTBs, you’ll need to make sure the rollers are long enough for that. Some are meant for track bikes and a lot shorter. The wheelsize doesn’t matter, it’s the wheelbase you’ll want to look at.
I’m quite happy with the Elite Motion:
The movement helps a lot for standing up. The 3 levels of resistance also do a great job. Vo2 sessions completely fine without running out of gears. +/-330/340w for me. You can put 400 as interval I believe. I’m mentioning this as I think resistance is a big factor, some rollers will spin out quite easily.
Most of them are adjustable in length to accommodate different wheelbase. By the way, the wheelbase is important, not the size of the wheel.
You can get the Nero for a little bit more than the quick motion now :wink:
Yes, thanks. I should have been more specific in that my bikes are road (Roadmachine) and gravel (Diverge, Jena). I suppose MTB is an option for someday, but I have none right now.
In either case, I assume most relatively high-end rollers are adjustable. But that’s really my question… which rollers are highly recommended that are of great build quality and reliability, with good-to-great features?
I don’t need something Tour de France riders would use, of course, but I’m definitely not looking for “cheap” or “budget” options.
And of course, I’m trying to understand the pros/cons of rollers versus something like the KICKR Move. The entire subject of rollers is new to me.
Avoiding the bare bones budget stuff, the leading one’s I’d consider, all of which allow some amount of length adjustment for typical road bikes. Some “MTB-like” gravel bikes with longer wheelbase may exceed the limits, so check specs for any you consider:
  • Elite Quick Motion - Includes fore-aft motion for comfort, adjustable resistance and compact folding option. Long time favorite for many (including Jonathan) despite the largely plastic construction.
  • InsideRide E-Motion - I’d recommend the regular resistance unit, not the electronic. The design that launched the fore-aft motion revolution ages ago, and are some of the most respected rollers on the planet. Lifetime durability investment and some of the best riding rollers around.
  • TruTrainer - Also non-elect resistance recommended. These are on par with InsideRide above with a different take on flywheel that they claim eliminates the need of fore-aft motion. I have not had the pleasure, but hear they are some of the smoothest rollers around as well.
  • Kreitler - Used to be the king, but are rather basic when you look at them. Possible to add stuff like headwind and large flywheel, but the cost is not in line with the options above.
  • TLDR rollers are fun, but demanding.
    • They add a massive amount to the indoor riding experience, but make doing higher efforts more challenging and border on dangerous at times. I have had more than a couple of close calls where I was happy to have a wall on one side and bench on the other to catch myself in a recovery after a massive effort.
    • The fun and engagement of balance on rollers becomes as detriment at times if/when you do maximal efforts. The effort is usually fine, but the recovery can be the tricky bit IMO.
  • Those close calls above are what lead me to make my first rocker plate. I wanted some of the freedom (and comfort) that comes from allowing the bike to move vs rigid trainers, but wanted to limit that just enough to remove the risky bits from rollers. The Kickr Move you mention gets most of that with less lean action than I personally want, but they seem well liked by those that have used it. The Motion Plates for the Tacx Neo trainers or new 3M head down as similar road.
    • I loved my DIY motion rollers, but there’s a reason they have lived in the attic since 2015 after I made my first rocker. Not enough benefit to the rollers for my taste once motion is added to trainers.
Wanted to share my experience with Trutrainer rollers. I started with inexpensive plastic rollers and and was using them with zwift and cadence and speed sensors. I upgraded to Trutrainer rollers again with speed and cadence sensors - so not the whole Zwift experience. The Trutrainer basic rollers are well build and a bit easier to learn compared to the plastic rollers as the design builds up momentum so you can coast like riding outside. Trutrainer added an upgrade a few years back (Smart roller) so it has variable resistance, can measure power output and responds to inclines in Zwift and Rouvy which makes the experience more engaging. The rollers generate their own power source when you start peddling - the designers were engineers. You don’t need to plug them into an electrical outlet.
The drawback I found when using Zwift is going up hills becomes challenging as you lose the gyroscopic force as the wheels slow down. Steep inclines on Zwift are > 10 degrees and my virtual speed is low so it the bike becomes more tippy on the rollers. I’ve also had the experience where going around virtual corners makes you want to tilt the bike and it becomes a bit vertiginous when trying to maintain balance. Trutrainer offers a front fork stand which locks the bike on though they recommend not standing up in this configuration. It also defeats the purpose of having rollers in the first place instead of other smart trainers where the rear of the bike is locked in. For the most part I use them with the front fork stand where the bike is held in place when using Zwift unless I’m on a relatively flat route.
The company has been very easy to deal with - there were some initial teething problems with the the smart roller component and they have repaired / upgraded free of charge including the shipping. I’ve used them both with Rouvy and Zwift - quiet and smooth and works well. I’ve had the occasional mishap when using them not locked in and wasn’t paying attention - no falls, just the bike coming off the roller and making a horrible noise as the wheels contact the frame.
I’m just an average guy that likes to bike, by no means a serious athlete and have found these rollers a pleasure to use - obviously easier with the front fork stand. I suspect better cyclists would easily be able to use them without the front fork stand on all Zwift / Rouvy routes. If your sold on the idea of rollers, it’s worth your while spending the extra $ for good quality ones - the Trutrainers have been very good and the company a pleasure to deal with.
Greg
Does anyone have any idea how to reduce vibration? I’m am plagued by a low frequency vibration which seems periodic. I have replaced all drums (including axles and bearings, Elite changed the design of the drums btw)and the drive belt of my Nero but the vibration remains (tested with 2 bikes)
Make sure that the ground is flat and even. My rollers have adjustable feet, and if one is slightly too high or low, I get vibration. I’ve also tried putting a mat under the rollers to dampen vibration, but wasn’t sure if it did much.
The flooring is laminate, so should be reasonably even (even though the underfloor is a long term project for me) and I tried a trainer mat but it interferes to much with the motion system of my Nero
