Thanks, good to know. It’s weird, tried multiple browsers and 2 different devices, and can’t get the workout page to load with workouts showing. It’s just blank. Finally got it to work by going directly through the app.
2% is an arbitrary target for sure. Polar H10 for error for cycling is about .6% of an ECG according to a white paper, but up to 5% for all activities. If you ask me (you didn’t
) you’re not seeing much decoupling in those intervals at all, let alone that decoupling over 20 min isn’t a great measure, and for rides that are like 3-6 hours long, I target 5% as the marker of aerobic fitness, but certainly not as a hard and fast progression rule. You’re talking about a change of 1bpm over a 20 minute interval making the difference between a “good” workout and a “bad” one (3.4% isn’t “whopping”).
Sweet spot crosses pretty heavily into glycolytic energy, so using aerobic decoupling for something that is necessarily a good bit glycolytic is a mistake IMO.
Further, HR is not a good indicator of fatigue generation, let alone why are you trying to do back to back 4x20s or tempo the day after a big SST set? More likely you were tired because most people get tired after doing a 4x20 at 90% of threshold, and now your heart rate response is better because you’re likely working at a lower % of your FTP. To wit, looking at my most productive offseason, in my 4x20 workouts I saw up to 6% decoupling in single intervals, and 6.4% decoupling in my 1x90 workout. Nothing wrong with that… that was taken from the year where I achieved my highest W/kg and best race results.
When was the last time you properly tested sustained power/FTP?
A lot to unravel there, but I think you’re just overcomplicating your training with confounding factors.
Yeah, doesn’t work in browser. I imagine getting it fixed is low priority for the TR folks since Teams functionality is deprecated.
Makes me wonder a what TiZ duration one reaches the point of diminishing returns. Probably where you ended at 2 hours sweetspot for training efforts.
That’s a fair question, I guess it really depends on one’s goals. I’m sure if you’re doing stuff like long gravel races etc, then extending TiZ even further than 2h could be beneficial, but for me (racing mainly road races that last less than 3h) 2h TiZ has been plenty.
@ivegotabike I must say that I pay no attention to my HR in general, as it varies greatly depending on fatigue, sleep etc. For example, in my best ever 5min effort, I hit my max HR (193) with an average of 188. Earlier this year in my former best ever 5min effort I only hit a max of 188. Both of the efforts were maximum, but I guess that in the former there was a bit of residual fatigue that subdued the HR response.
I just try to hit my power targets and let the coach analyze the HR data if he so wants.
@ChrisDe good point, that might also be the case! ![]()
My concern is not fear of “losing it” but rather doing VO2 during a period in which my FTP is not at its peak. That is perhaps my only “fear” in this new approach I’m curios to test out.
The rest of the periodization you’ve laid out is exactly what I have in mind.
Target event in June, so I’d be starting a vo2 focussed block in december and january a mixed block. From then onwards the focus would be on threshold and sweet spot.
Historically I’ve always done the “classic” SS plan over December/January and even February to then move to vo2 and then threshold. So I was curios to change things a bit also considering the cold weather in winter does not really support doing long hours outdoor.
Im
I’m not a coach or sport physiologist but based on my own experiences. I would not use the Ai FTP or ramp test if I was worried about aerobic decoupling. My hr can be ±5-10+ bpm on short all out efforts.
Also how do you track aerobic decoupling in the summer? When it’s 85° at 8 am with 75% humidity my heart rate on an endurance ride will get into zone 3.
I have learned the power of RPE and only do long form tests as a way to determine my FTP.
I’m honestly amazed at how many people train hard, dive deep into determining which workout/week/plan is best, develop a deep understanding of all kinds of different science and training methods, fret over whether they should target +/- a watt or two on an interval…but never actually test their ftp.
Sure don’t, but we didn’t compare sweet spot decoupling numbers after the races. I’ve trained about 15 riders for the last three seasons and I can tell you that I don’t spend any time whatsoever looking at decoupling numbers in sweet spot workouts because it is not a meaningful metric for that particular type of work.
No quibbles with the training you are doing overall, just this one thing.
I recommend: 1) do a long form FTP test (kinda just my preference, if you are happy with your number keep it); 2) progress your TTE when you achieve the workout without unplanned breaks, 3) stop looking at decoupling for short and somewhat glycolytic efforts. I believe your FTP is maybe a bit low based on your HR trend (though it could be correct - I don’t know your history), and that you are unnecessarily limiting your progression which ultimately will cause you to underperform a lot more than if you have 3.4% decoupling during a 4x20 instead of 2%.
Now, this is all unsolicited advice, I admit. I hope you enjoy your training. Cheers!
You don’t need to worry about “peak” FTP, but you DO want it to be in the ballpark. Like say you’re a 300W guy, you’d want to be hitting VO2 when you’ve gotten up around 290. You don’t want to do a big block of VO2 when you’re off the couch at 260 or whatever. But I wouldn’t worry about getting those last few watts. In my experience, most people are pretty close to previously achieved FTP values following a quality block of sweet spot/tempo base work.
I’d caution against the mixed block (including VO2max work) following focused VO2max work. More is not always better. This obviously depends on the type of VO2max work you’re doing, but in general, if you’re doing a big block of VO2max, I wouldn’t follow it with smaller doses of VO2max. The mixed block post VO2 block isn’t going to provide enough stimulus to solicit a gain in VO2max given the massive stimulus you just gave it, so you’d be better off focusing on just raising threshold at that point. If you feel like you must chase the highest FTP possible before VO2 training, do the mixed block before the VO2 block. Again, my $0.02.
Thanks!! very interesting perspective on the mixed vs dedicated block especially as I feel my fitness is still lagging after my post season break.
If as suspected you’re referring to accessing Teams via the main left-hand-side TR menu (menu item “Teams”), then this issue of all the workouts being missing was flagged up by me and acknowledged as a bug by TR on October 17th…
The workaround for now is to access the Team’s workouts via the “Workouts” menu item in the LHS menu instead (not the “Teams” menu item), and then use the Filters controls to display just the workouts from the Team of choice:
Thanks, I eventually figured out that I could access them through the workouts page directly, or via the app through the teams option.
No worries.
Best of luck.
Might be a good idea to do that mixed block just to get things moving before VO2max. Don’t expect miracles with a single block, but if you’re lagging, it might work.
The other thing that might be is not enough recovery from prior training “seasons”. So some recovery might be required before it’s “too late” to take a week off or so. Did you take an offseason break? If so, what did it look like and how long were you training hard before it?
Oh I took the usual week off (also got sick in those days). The comeback over the past two weeks has been somewhat slow so the past couple of weeks were also low volume although I started to insert again tempo and a sprinkle of threshold.
You might have a bunch of long term fatigue you need to get rid of. A week off may not be enough, especially if you got sick. If you’re feeling sluggish two weeks in, that’s most likely it.
Sigh…I think my AIFTP is set too high. A well fueled 3x16 SS session was way harder to complete than it should have been forcing me to stand multiple times to finish. The watts gained on my FTP over the last couple of months can not be accurate. I suspect my singlespeed MTB rides on the weekends may artificially inflate my FTP. I will lower it by 10-15 watts and feel it out. Just here to shed a tear.![]()
Are there any triathletes following this sweetspot progression? I think this could be favorable, not?
I started tri 4 months ago and working towards a 70.3 in July. Because new to swim and have to start running again after 7 years. I wonder if it is not better to follow a bike sweetspot progression approach towards 1x90-120min…and just do my swim workouts and base running? Instead of specific HM Tri training plan here on TR? Normally I am already not that far away from 1x90min at SST. So maybe even better doing a vo2max block, but is that doable with swim and run?
Very favorable. Very very very favorable
Ok. WIll think about my approach. I have a 70.3 planned in July. But half May I have a 1-1-1 Triatlon also. That is 1k swim, 100k bike, 10k run. With my bike background that is better then a 70.3 as first event.
Maybe first step is do a new FTP test (did not do one recently). And then decide if I continue you my TR HIM plan or go to a SST progression block. Problem is that normally I am already good at riding tempo and sweetspot (better then riding at FTP or above). So maybe I should focus on FTP or Vo2max sessions and wait for my progression 10-8 weeks before my event in May? It is 14 weeks till that event.
Because my swim is more technic based and my run is just low tempo increasing volume (no intervals) I think it is better not to use the TR HIM plan but do the SST progression block with the 2 other sports?
@kurt.braeckel do you also coach Triathletes?
At some point you need to do sthg else than sweet spot. And asyou can already do long ss intervals, you should maybe focus on vo2/thresold for some weeks and come back to SS later on.
Be careful with a pure cycling plan, it doesn’t take account of swim anf run, so it could yields a lot of fatigue especially as you are a newbie(as a triathlete, don’t take offence).
Curious of what @kurt.braeckel or @JoeX have to say on this
Thx @ThyTri . Some good remarks there. Maybe it is indeed time to focus on other stuff.
I also will be aware of the fatigue (certainly not feeling offended, don’t worry). Some background. Last years mostly averaged between 10-15h per week of cycling. (6 days a week). So now falling back to 3 or 4 sessions I have the feeling that that is manageable with swim and running. My running is also (due to injury few weeks ago) 3/4 times a week but still not in high volume (currently at 25-30min sessions). So when I will increase my volume it will be automatic that my cycling intensity and/or volume will lower.
But for the moment, I have the feeling I can incorporate some more structured cycling plan in to my schedule and when I am 4-6 weeks further I focus again on a more Tri HIM plan? That is my thinking behind this approach…
@JoeX already give some good advices in the Tri topic.
