Good day everyone!
I’m struggling with actually displaying Left-Right balance on my Garmin Edge 1030 Plus. The PM are linked by Ant+ (showing the left PM in the sensor menu of the Garmin) but only showing wattage balance on the left crank
I have performed a hard reset and a zero reset of the PMs. Both PM and Garmin firmwares are up to date.
What am I doing wrong?
First thing I would check is that Garmin is using ANT+ and ONLY linked to 5554 (left side).
Assuming you are seeing the same 100%-0% post-ride in Garmin Connect?
I confirm that Garmin uses Ant+ as sensor name is 30184(left) whereas BLE sensor is named Stages_30184. And only 30184 is linked on the Garmin. Ant+ code on the physical left crank is 30184.
And I confirm that in Garmin Connect, it shows 100%-Left and 0% right.
(removed screenshot)
30184 is RIGHT SIDE
You need Garmin to disconnect, and only pair with 5554 LEFT SIDE.
Sorry my earlier post is WRONG.
LEFT is 30184.
Hmm.
Yeah, I opened a ticket with Stages to help out. I wonder why the balance is not showing properly. It defies the purpose of having a dual-PM…
I’d reset the right side, and then view live power in the Stages app.
I tried but still without success.
If the Stages app is not showing power from the right side power meter, then you have a serious problem not involving the 1030.
Well, I just contacted Stages tech. After doing hard reset, ensuring that it calibrated properly, We did a test with Wahoo app, left PM shows Watt while the right one don’t…More to come
Stages will replace the right Powermeter that is at fault!
