SSB II is killing me
great. I have that workout next Monday. Something to look forward to!
I’m doing SSB2 HV and it’s been a slog for the first two workouts. For reasons too long to explain, I use the Hammer with TR and send the assioma uno power to my gamin and zwift. Usually the two sources are in agreement, but not the past couple of days, so for example today’s intervals which were 20min at 88, 92, 90% were actually 92, 95, 91%
I tried to adjust the intensity down toward the end but the muscle fatigue was too high from the earlier hard efforts, so even doing a very doable 90% was tough. I’m in good shape but not that good yet! Needless to say I need to lube my chain and recalibrate, and honestly I should probably try power match and see how that goes
How about “remind myself the vo2max workouts are designed to be achievable if you adjust % above FTP to your physiology:wink:
Well that went better than I thought. I’m battling a cold, so I wasn’t sure how Lamarck was going to go: 4x10 minutes right at FTP, but only 2 min between. My FTP is set at 289w.
1st set: 297w
2nd: 303w
3rd: 301w
4th: 313w
I pretty much emptied the tank on the last one. I’m pretty stoked I was able to do those numbers in the last week of SSB2!
Training zones at FTP and below are just fine :smile:
Above FTP the ability to complete work is highly individualized. TR stresses this on podcast and workout notes.
It’s interesting to find I’m not alone. I found SSBMVII left me deeply fatigued towards the end. I would be inclined to insert an easy recovery week in the middle next time around, just to make day to day life outside of the workouts that bit easier.
Man I’m glad this thread exists. I’m wrapping up SSB2 MV and I feel like I’m just breaking apart physically. Completed every scheduled workout at 100% for SSB1 MV, but volume 2 is a different story.
Week 3 Saturday had Carpathian Peak +2, had to turn down the second interval and never even started the third cause I knew I would be sloppy so ended incomplete.
Week 4 completed at 100%, even Mary Austin on Saturday and 5x15 SS on Sunday
Week 5 just feeling tired, subbed out Lamarck for Carillon -4 on Thursday to save my legs for the weekend, but today had Leconte and barely made it through 40 minutes of work, ending it right before the last 2 10 minute intervals. Tomorrow had Wright Peak -1 but think I’m gonna do Koip or something similar
I don’t really beat myself up too bad about it, but I do feel like I’m “failing” some of these weekend rides, especially today where I just had a hard time turning the pedals. I’m hoping this easy week before General Build will help me recover and get my act together so I can power through build. Any suggestions?
I posted on this before but I found that the SSB2 has a ton of high SS and threshold work back-to-back; the high SS work is basically threshold work and some of the long weekend rides (2h rides) were just too much the day after the O/U.
It’s pretty easy to see what the “key” workouts are and I just targeted arriving at each key workout as fresh as I could, where I nailed the O/U work and that was the weeks goal. I only had issues with Carp peak and I think it was due to external factors, but otherwise I nailed all O/U workouts. However I did find the ride the next day (long SS ride) was sometimes just absolute death, especially after MA and Leconte. I would sometimes just sub an easy ride for these; I personally thing having them back to back too much and if I was able to do the O/U on friday and a long run on saturday, I would be able to get the long SS session done. If I did the O/U saturday and the long SS the next day, I would basically just sub the long SS for something like baxter. It was just too much intensity too quick back to back and it was not an endurance thing (again the long run was a “recovery”) but it is just too much intensity too quick for me. The long SS is also really close to low threshold, and when fatigued its basically death.
Don’t feel bogged down on those O/U rides; they are HARD. As a triathlete, I feel like they are my strength and I still find them really hard, even when they are going “well”. I feel like if you nailed the majority of the rides and had to sub some of the long SS ones out, you are still fine. Again, I subbed some of the long rides out and also subbed the VO2 max rides out and I still gained a few % and feel super strong going into the full tri plan. I personally only focused on the O/U rides and tried to put as much as I could in after without compromising my O/U workouts.
Also to note that theres more to your fitness than FTP; I 100% felt stronger after SSB2 and even if my FTP didnt budge, I would have been happy because for sure my endurance improved
I totally agree alot of people don’t have the endurance base for SSB2 on top of six weeks of SSB1. It was my case and lot of others I see on the forum. TB even low volume is almost mandatory. Add to this that we are the same people who get massive FTP bumps like 10,15,20% between SSB1 and SSB2 and we never worked that hard, let alone on top of a tired body.
Could be youre a bit like me and overtest. Ive realised that I was finding SS way harder than it should be and looking at effort I think I overtest by 10% (maybe more). Im doing a number of repeats of TB in case its my base which may need some significant input (which I think also contributes) but will be planning knocking 10% off of SS workouts from now on.
I reduced my last ramp test by 5%, and am doing a SS progression with long intervals at 85%. 2x20, 2x25, 2x30 and 1x60.
I’ve found these are better vs higher intensity shorter intervals to tire my legs - as higher intensity SS intervals (e.g. low-mid 90s FTP) drives my HR up too high, and my cardio system starts to give out before my legs tire.
I also found I can do higher TSS with these lower intensity longer intervals. And there are no longer any workouts that I dread in anticipation of having to destroy myself to complete.
I’ll be following SSB1 and 2, modified to replace the TR SS intervals with the ones above.
I’m also doing few hours of endurance rides each week to improve my base - which needs work.
When I get closer to my races, I’ll be adding VO2max workouts.
Remains to be seen how this approach builds my fitness, but for now, I’m happy with the approach.
Last season, I struggled with the two hour weekend SS arises after Over unders. Two factors, I think: I was working on a major project at the house so I wasn’t recovering well after O/Us; my strength endurance isn’t what it is now.
This season, I sailed through the sweet spot stuff without problem.
So, improved strength endurance helps and ensure you’re focused on you recovery after O/U.
The endurance work would’ve paid off provided you had enough time to invest in it. Many of us don’t, and that’s where SST methodology pays real dividends.
I don’t think I’m testing high. SS normally isn’t a problem, it’s the over unders that get me. Pure threshold isn’t terrible either. I had no issues completing Eclipse and Galena which are 3x20 SS with minimal breaks, and got through 5x15 SS the day after Mary Austin. Just the build up of fatigue from SSB2 made the final week super difficult.
“SSB II is killing me”
I totally agree with this comment.
My other opinions on it…
  1. I’m in my third successive year of SSBLV 1 and 2. Part 1 is the calm before the storm. Part 2 is HARD.
  2. I’ve learnt to not increase FTP after part 1 as I know I will not handle the hike in the difficulty factor.
  3. Part 2 is real character- (and FTP-) building stuff.
  4. Lamarck is effectively an FTP test (4 x 10mins at 100% FTP). If you can JUST complete it without actually dying… heaving lungs and maxed-out HR… then your FTP is set perfectly.
  5. I over-perform on ramp and 20 minute FTP tests, so I now use Lamarck as a benchmark assessment of what my true FTP is. It’s proved a much more reliable measurement device for me personally.
My advice for SSBLVII newbies: just grit your teeth and get through it as best as you can, turn it down from 100% as and when needed, but try not to!!
I’m not sure if I agree with your #4. When I really push Lamarck, I do them in the 103-105% range. If your FTP is correct, you should def be able to go over FTP for each with the intervals only being 10 min and getting rest between.
I’m only talking of my own experience - if I can JUST survive Lamarck at a given FTP then the following workouts (whether threshold, over-nders or VO2 Max) are JUST achievable. Perhaps when I’m on the absolute ragged edge to survive Lamarck, my FTP is actually set a little bit too high?
I would say if you are JUST able to survive Lamarck, assuming you are sufficiently rested of course, then your FTP is most likely set a little high.
I think a common mistake of TR users think for a workout to be successful they should just barely be able to finish them. Seriously, if that is the case, then something if going to give. This is a pretty stressful way to approach each training session!
I have had coaches assign me 2x20 min at 105%. Yes, this should be very hard, but it shouldn’t bring you to your knees. The best coaches will tell you that you should be able to do one interval if you had to, so there is always a bit left in the tank as you are already preparing for the next hard day.
Keep in mind that Lamarck has 3x2 min rest intervals. If FTP is set correctly, then you should be able to ride for 40mins at FTP with no breaks.
If Lamarck feels like you describe above (this is the way it felt for me last time), then FTP is likely set too high.
Edit - I read the posts from @Ian747 after I wrote my post. Agree with his POV. Sorry for the duplicate comment!
:flushed:
