Sram AXS suspension lockout
As we probably know by now Sram filed a patent for wireless suspension lockout earlier this year.
Some initial pictures have surfaced of this new technology.
Using the same battery as other AXS components:
https://fccid.io/C9O-FSMB2/External-Photos/FS-External-Photos-04082020-5104291
Rear Schock & Manual:
https://fccid.io/C9O-RSMB1/Users-Manual/User-Manual-Electronic-Suspension-final-5104323
The system works based on a crank based sensor that detects if you’re pedaling or not. This can automatically adjust your suspension setting, or you can manually override these with the handlebar remote.
Looking foreward to the initial impressions when it releases, though I suspect it will be very expensive and a fair bit heavier than our regular cable actuated lockout.
Brain but with an actual brain
Pretty cool. So you can probably independently tune your “pedaling” mode from your “coasting” mode.
