its definitely messy to apply. it was one of the reasons i wanted another option. I need a floor cover and a very thick towel to not make a mess all over the place
You rewax after you boil.
Iām guessing thatās why they donāt actually show them applying it in any of the videos. Itās a lot easier to just tell people itās easy to apply than to show it lol
Will boiling water deform plastic jockey wheels?
Arenāt these videos sufficient?
TL;DW cross chain position, apply from top of cassette, one drip per link if you want to minimize amount, apply night before a ride.
More tips:
Your photo looks normal to me. Thatās dried wax that repels dirt. I donāt bother wiping it down afterwards. All I care about is how smooth and quiet shifting is while I extend the time between full dips.
theyre plastic!?
maybe boiling isnt best idea because of the bearings inside
Just pedal bike and use a flat head to shave it off
Look at Silca site again. Josh has a very clear video on how to apply it
I watched the whole thing. Didnāt see him show it
Thanks, thatās about how I did it. I used a little more than that
With Super Secret I do one drop at a time on each link. I do put paper towels under the bike but by only putting one drop on each link I donāt get much dripping. However we I shift the chain up and down the cassette after applying a little bit does fly off.
I wish Silca would come out with a tip like this product to make applying Super Secret less messy
I wonder if that cap will work on the SS bottle. I know the muc-off cap is the same threads.
Looks like you canāt buy it. Sold out.
3d printer anyone?
Cap is a 24-415 but a 410 would prob work.
You can just buy the luberetta and fill it with Silva secret wax. Thatās what I have done.
Edit: Sorry, it looks like you mean that that luberetta is sold out.
Sometimes it takes a bit of trial and error to limit the mess. While itās not a perfect solution, Iāve found the following procedure limits the amount of excess that runs offā¦
- cross chain as per the Silca instructional video (big ring/ big cog combo)
- one drop per roller on top just before where the chain contacts the rear cogā¦the articulation allows more of the wax to get inside vs running off
- Only crack open the twist cap enough so that a light squeeze pushes out a single dropā¦
Iāve found that step three above drastically limits the excess thatās drips off onto the floor⦠YMMV
Only thing Iāll add is that sometimes a bit of a crust develops on the end of the twist cap, so be sure to scrape that off with your fingernail.
