Shimano 600 Tricolor
I have a Shimano 600 Tricolor, I believe 6400 front and back derailleurs. pcpartpicker I also have the standard chain rings, tricolor crankset with a 113mm spindle length square taper bottom bracket. My wheels can fit a 10 speed cassette on the back, reverse phone lookup but I’m currently running an 8 speed without any issues. Would I be able to use my current derailleurs and crankset (113 spindle length bottom bracket), nba reddit and just switch to a 10 speed cassette and switch out my shifters? Do I need to change the pulley wheels or chainrings for a narrower chain? Do I need to change my bottom bracket spindle length?
Ask the same question on the forum of either
  1. Retrobike or
  2. YACF
and you’ll get a quick reply from their many experts. There’s not much old school equipment discussion in this particular forum.
You should be able to run 10 sod just fine. Cassette spacing for Shimank 8-10 Spd was a, the same. An 8 sod free hub can run 10 sod and vice versa.
You will likely need a new Front Derailluer, however…Try the 8 spd and see if it works, but the narrower 10 sod chain will likely not play well with it. I always had some rub somewhere whenever I tried it.
Get new shifters, cassette, chain and maybe a FD and you will be good to go.
