Selecting Solo Outdoor v TR Outdoor
Can someone point me to why I would choose one over the other for any given assigned endurance or recovery workout on my calendar if the one thing I know is I want to ride outdoors that day?
Solo outdoor is an unstructured ride outside, TR Outdoor is one of their structured workouts outside.
When I decide to do an unstructured ride rather than the scheduled workout, I just do the unstructured ride and don’t bother changing anything in the calendar. I just leave the planned workout undone. AI sees the unstructured ride and appropriately adapts the plan and FTP prediction. The WX here has been unseasonably great and I’ve done that a lot.
Okay, but does it matter which one I choose? Are there any differences in downstream impacts on the training plan? Advantages/disadvantages. Either way, I’m going to ride around endurance for an hour or two.
Say it’s an hour endurance ride. If I do the structured ride, does TR account for that data differently than if I just call it a solo ride, but still do essentially the same amount and type of effort?
Depends what you are doing. If its my commute I label it as a Solo ride, but if its specifically a TR workout I’ll label it TR Outside. Id only assign stuff to a TR Outside workout if it was a TR workout but I doubt at endurance level it’ll matter down the line though. The problem some folk got was associating an unstructured ride to a higher Zone ride and not actually getting the physical benefits of a workout but getting the points (PLs) of one, and therefore struggling down the line.
For endurance, probably not. Ride at a smooth and consistent pace in roughly thr band, TR will use it.
If, however, you were proscribed a VO2 workout and then planned to ride a TT you should definitely update that.
The difference in benefit is whether you hold the structured ride, or vaguely stay around target. The former being more beneficial than the latter.
Hey @maytree :slight_smile:
As @HLaB mentioned, if you are riding unstructured then Solo Ride. If you are going to be following the TR Workouts instructions (even for an Endurance workout) then you’d choose the TR Workout. We only recommend matching a ride file to a TR Workout if you actually completed it.
Okay, but it still doesn’t tell me why I should just Solo Ride over the structured workout or vice versa, when I’m going to be doing more or less the same endurance ride – say my TSS/IF are more ore less the same either way. What if any considerations should I take into account in choosing one over the other? Is there any difference in impact on the training plan?
If I’ve learned one thing about cyclists, it’s that “more or less” usually means “not remotely”.
Just do a mind’s eye visual check. Does the power trace for your ride (hypothetical or actual) look like a workout? Or does it look like an ECG of a gerbil with access to stimulants?
In the past it was an important distinction, but with the new AI, I’m not sure. I do not do anything in the calendar when I do an unstructured ride. It uploads to TR and I rate it afterward. I don’t identify it as a Solo ride, or associate with a workout in anyway, or delete a scheduled workout I don’t complete. So far the plan adapts and FTP prediction updates after each one and seems to be working as expected. And as of late, for the past 14 days I’ve only done unstructured rides and it keeps working as expected. In fact, it just gave me a big bump in predicted FTP over what the plan originally predicted. IDK if that’s a result of my unstructured rides, or a tweak they made to algorithm.
Maybe this is what I need to be doing. I like to mix in my 60 min TR workout into a 2-3 hour ride sometimes. Like, I’ll do an hour of z2 to the area of my choosing, do the workout, end it, and keep riding. Every time I do this, the AI ftp seems not to like it and knocks me down a bit. I’ll ‘match’ the outdoor ride with the workout, but I guess that it’s not a 1:1 and TR doesn’t like it.
Yeah. IDK. That seemed to be what I used to get. My thought was that the AI created a plan it thought was optimal and any deviation, going more/less, harder/easier, would be suboptimal with respect to the plan’s inputs and would result in a lower predicted FTP. In the past, it was a big no-no to associate a ride with a workout unless is was a best effort at complying with that workout. I think back then, the system didn’t look at actual performance during that ride but rather just considered the workout completed successfully. My impression now is the system just looks at all performance equally, structured and unstructured, and goes from there. That seems to be what’s happening in my case.
That difference doesn’t make much sense to me. The “Trainer Road Outdoor” option (as opposed to indoor) gives a broad range of power for endurance workouts to stay within, for e.g. today’s was an hour pretty much assigned to be between 113 and 150 watts. Literally, that’s what it tells me to do “ride between 113 and 150 for the next X minutes). I think people here are confusing the more targeted TR Indoor structured rides with the TR Outdoor ones. So assuming that I stay within that range, which frankly is not that difficult, what difference is whether I choose “solo” v. “TR Outdoor”?
You mean difference in how TR processes it?
So mrtopher1980, thanks. If I understand correctly, if all things are going to be basically equal – and given the TR Outdoor format of prescribing a large endurance range (113 w - 153w, for 45 minutes, for e.g.), it’s frankly not that hard to make them meaningfully equal – what I should do to decide which to choose is whether I care about if my Progression Levels are updated or not. So that’s going to beg the the question – do I care if my Progression Levels are tracking work? I guess I don’t know how to judge whether I should care. Maybe if I’m trying make sure I have the endurance for a very long event, I care about that metric?
