Seems like ERG isnt all its cracked up to be
Awesome news, and congrats on the initial performance gains, as well as your new focus. Sounds like a good direction a d you can already see where you need to go. Well done. :smiley:
226W for 2:20 at 260 FTP? 0,94 IF? Are you sure that your FTP is set correctly? Or you have VERY impressive stamina.
Yeah looking at that the ftp is definitely not right personally I reckon the ftp is around 275 give or take a couple watts. Also remember the cost to the rider was nearer 235 not 220 so that actually brings the IF up a bit. Out of curiosity how does your heart rate zones compare to your power zones. They are always a good indicator if your zones are about right
Entirely possible…I did 2:28 @ 233w last Saturday after testing my FTP twice the week before. Ramp test said 250w, but that seemed low so did a race up the Alpe and got 255w. (FWIW, I have my FTP in TR set at 260 and will probably bump it up to 265 next week).
But yeah, I can sit at SweetSpot all day long and just keep grinding away. Definitely a strength for me.
226W is ~87% of 260W (FTP). IIRC that is the high end of TR’s tempo range. Doing that for a couple hours should not be a big ask. It doesn’t happen overnight, but is not special. If all you are used to doing is short intervals, it might be as much mental as it is physically tough to sit through hours of steady tempo. Personally, I like to see at least 3hrs at 85% as a good fitness marker.
Long Zwift group rides are great for this kind of training stimulus. The pace is pretty constant and the groups big enough to make drafting easier. Also, the big groups help w/distracting you via chat, sights, etc…
Yes, 226 at 260W is no biggy. But there was a case of 0.94IF.
I’ve been riding outdoors this week after doing all my training inside since august. It’s interesting because some of my feelings on erg mode were validated, with the flywheel on my hammer and my gear selection I’m pretty consistently in the upper 90s for cadence, whereas outside I’m in the upper 80s. I also ride 8 speed so I have the added thing of jumps between gears where I can’t always dial in the power I want at a cadence that is in the comfort range for me. I think mainly I need to practice with the outdoor pedaling, so I wouldn’t blame erg mode, and I have no intention of leaving erg, it’s been too good to me lol
If NP was 234w and IF was 0.94 then he must have had his FTP set to 250 not 260.
260 FTP would have given (234w/260w =) 0.9IF
Yes, this sounds like a trainer issue.
I used a KK trainer with ERG mode. I was in a foul mood for a week, because I had a bad FTP reading. All totally false, as i found out when I did subsequent workouts over 6 weeks. But I also always used a HR monitor, and RPE every time. As an experienced cyclist, I know the HR and RPE I should have for a sweet spot session, close to FTP . 150-155. In over unders it goes up to 155-161.
So doing over unders 2 weeks ago, I noticed my HR was 109-115! RPE 4!
Changed to resistance mode, and got appropriate RPE +HR.
Got new trainer, a Cyclops Hammer 2, thanks to Chad Mcneese s recommendation.
It is great, and seems very accurate.
I don’t compare against Zwift, or outside riding.
I think the answer is; get a new trainer, and end your frustrations. Worked for me.
Funny you say this I was just about to post an update!
I got rid of the Kickr Snap pretty soon after this for a number of reasons. (Erg mode was poo, inaccuracy, constant calibration, noise etc). Upgraded to a Tacx Neo 2t and its been a dream.
Still been training pretty exclusively in erg mode, but with this trainer the line goes up and down on the workout chart depending on how smoothly I pedal, so my form has got a lot better.
Have been doing well in Zwift races and maintained 260 watts for 3 hours outside today so I’m very happy with the progress.
In short - erg wasn’t the issue, my crappy trainer and the smoothing was.
Thanks for posting your update!
Glad you’ve got a really good trainer now.
Your Kickr Snap sounds like my Kinetic. Except my K seemed to work ok on Zwift.
The nice thing about erg mode, when working properly is ,(for me) learning to pedal smoothly at a high cadence, maintaining the watts without having to adjust my power output . I was always a high gear grinder, but now can pedal comfortably in Sweetspot in a high cadence.
Well done for 260 watts for 3 hours! wow!
