Road tubeless tires - What’s in your spare kit?
I’m on the GP5k wagon. Already used them for one half and one full Ironman and I’m really happy with the tubeless performance.
My race day kit is about dynaplug and co2 only. For training rides I’ll take a spare tube kit in addition to the tubeless kit.
Very similar to the others, here goes:
  • Rene Herse Tyres 700C x 35 Bon Jon Pass TC - Orange Seal sealant
  • Tubolito CX/Gravel Spare Tubes x1
  • Racer DynoPlug - life saver
  • Tyre Levers - Canyon prototype design
  • Puncture repair kit
  • Contact lenses - just incase one flys out
I get ~4,000 - 5,000km from a rear Pro One 28mm (ive done 25,000km+ on them in total, so gone through a few), this is with the older model, they released an updated version late last year, i havent tried those yet
For me they are cheap (about $65AU) compared to $100+ for GP5000, and ive never had an issue with them so I am not changing anytime soon
Can also report I had a slow leak puncture (didnt even notice it until after the ride) which wouldnt fully seal even after a few more rides (still just very occasional slow sealant leaks, not losing significant pressure) so I stuck a plug in it. Has been fine ever since! Would definitely plug again
Dynaplug sounds like a “must”. Do people prefer the Dynaplug race, pro or air??
I carry much the same. Tube, dyna plug, levers, multi tool, but also a spare valve core and core removal tool. This isn’t specifically because of tubeless but I’ve had a valve core break off when inflating after a puncture before so we’ll worth it I think.
I forgot to mention these, I carry both as often a valve can get gummed up, also if I need to add sealant I’d rather do it through the valve than break the bead…pumps also love to unscrew the valve when taking them off!
All my MTBs are tubeless but on road the smallest tyres I’ve used it with have been 35c. Sealant works best at lower pressures - you aren’t forcing the air, and sealant, out in the same way as at high pressures.
My tubeless kit is:
  • Anchovies/tyre plugs plus applicator
  • Flexible super glue (Loctite powerflex)
  • Pump
  • Leatherman squirt
  • Needle and thread
  • paper tissue
  • tyre boot
  • tyre levers
  • Tubolito tube
  • spare valve core
The tube really is item of last resort, I’ve only ever been beaten by tubeless twice in six years - both times due to rim damage.
The needle and thread are for the occasions you rip or blow out a tyre sidewall and you need to prevent the tube from herniating out. If you are putting in a tube then use the paper tissue to run round the inside of the tyre to find any thorns then use the pliers on the Leatherman to remove them. The pliers are also useful in removing/replacing the valve core.
Tyre plugs: fit the plug, use the scissors on the Leatherman to trim so that there’s about 3-4mm of the plug protruding then cover with superglue and allow to set - it should be about done by the time you’ve packed things away.
It sounds like GP5000TL are over built to have tiny bit smaller diameter to ensure tubeless tight fit and hence the difficulty getting on. This is not necessary when the I industry finally settles on a standard. Mavic UST road tires works well on Mavic UST because they are not overly tight. Mavic UST road is not a standard because no one else is using it.
I’m not discounting that the Prime carbon wheelset could run big. The Pro Ones were difficult to put on too so 2 for 2 on the same wheels.
I believe GP5000 TL are the adopted standard, and so are the new Pro One model
Not sure who is making rims in that adopted standard yet though
Is there a name for this standard? I googled “adopted standard tubeless road bike” and I could not find anything.
Top secret :slight_smile: not even Dr. Google can find it yet!
ETRTO. One step closer to a road tubeless standard? And why this matters to you | road.cc
Standards are only as standard as the number of manufacturers follow them and how closely they follow them. Most seem to be “open to interpretation”.
I have the Roval CLX50s. Tire and sealant choice was a no brainer. The 28mm Specialized Rapidair 2Bliss and Specialized sealant. After hearing so many variable experiences with tubeless, I like the ability to run a “system” that was designed to be used together rather than crossing my fingers that different manufacturers play nicely together. The tire bead is designed for that rim. I was able to set up with just a floor pump. I could just be drinking the kool aid, but the sealant is marketed as being better for the higher pressures of road. The tires feel great. So plush yet fast. Running 60/65psi. I carry a dynaplug racer and tubolito spare to ensure I won’t need them.
Never was a fan of specialized tires. Light but never lasted long. How long have you got them?
I’ll have to Chek this option but the continental 5000 have my preference for now.
I’ve been on them for a few months. Couldn’t ask for more in the way of supple feel, great rolling resistance and grip- even on the wet, moss covered roads around PDX
I’m closing in on 2,000km on mine and they still have plenty of life. I’ve cleaned them out a few times and added sealant, but the tread is still in good condition. Don’t know if they’ll get to 4,000km like the other poster, but I’d say at least another 1,000km.
For my spare kit, I’m using a Specialized road bandit with 1 CO2, tube, levers, Allen key for thru-axle, and a $20 bill that doubles as a boot in a pinch.
