Road tubeless experiences
My Road Tubeless experience so far is miserable.
I have Reynolds Assualt SLG wheels and 25mm Pro One tires. The good news is that front tire popped on with no headaches and just a floor pump, it appears to be all good. The bad news is that I might of messed up the tape on the rear wheel which is causing a leak. I have been attempting to remove the tire to re-tape and it has been a nightmare to remove. The bead was and is still stuck and I can’t get it out.
Ultimately, this has me nervous about running this setup because there is no way I could do a roadside tube install if needed (unless the tires stretch?)
I have some new tape coming today and will try again but I’m close to writing this project off as a total loss.
Any tips or advice?
:frowning:
I took me three goes and about three weeks to get my first wheel right in part due to a big oversight on my part not due to the “system”. Second one took 24 hours. I will be sticking close to home for the first few rides when the snow finally clears (and my new bike arrives) in case I have to make “the call”.
I’ve only had to make the call twice - a sidewall slice and a failed bead. The sidewall almost made it home - was able to use a boot and tube, and that took me another 20 miles before that failed and had to made the call only 5 miles from home.
@gpl, how wide are your 25mm gp5000 tl on your rim? Aero issue or not? if the tire is wider than your 25mm rim then it creates turbulences.
I wanted to try 23mm TL (Victoria) on 25mm rim TL ready for this weekend HIM Galveston but failed to have the victoria seat on the groove (even bikeshop compressor didn’t work). Ending up putting tubes inside 23 mm TL tires :unamused:
Another ride using my kit to help someone else. Dude rushed from work and forgot his kit, handed him:
  • tube
  • tire lever
  • valve extender for his Zipp 404s
  • co2 cartridge
  • inflator valve
I’ve used the kit for myself exactly once since going tubeless. And at least 5 times to help others. A couple times just handing guys a valve extender because they had mid aero wheels and a tube with short valve.
#PayItForward
If you’re carrying a tube to fit in an emergency, one thing to check regularly is the nut holding your tubeless valves in place. If it is more than finger tight, or gets seized after a few rides in wet weather, then you won’t be fitting your tube, even if you can get the tyre off at the roadside, unless you have pliers in your kit… Maybe worth a drop of lube every now and then.
Something I came across on the net somewhere, and have used successfully with difficult to seal tubeless valves is to cut a small circle out of an old tube, and punch a hole a bit smaller than the valve stem and use it like an o-ring or gasket between the valve and the rim bed. Ive found a few advantages, since rim beds have different bends in them, this will allow you to seal better when the valve base doesnt exactly match your rim, and also with the valve nut, it allows you to have a bit of give by pushing on the bottom of the valve and relieving the pressure on the nut, making it a little easier to undo when necessary
Worth a try if you are having issues. I have a set of punches so its super easy for me to make one, would take a little more time without punches but still be worthwhile
Do you put the cut tube under or over the tape?
Pretty sure the hand made rubber tube/gasket slips on the valve stem before installation in the rim.
  • Valve Stem > Hand Made Tube Rubber Gasket > Rim Tape > Rim > Valve Stem Nut
Correct
I had no trouble with some rim/stem combos but this tip fixed the others up straight away
I guess I’m not the only fool to mistake the supplied rim strip on Prime (ChainReaction) wheels for tubeless-ready when in fact it is just a very tight fitting standard strip.
I just received an unsolicited customer support from CRC as a “Prime Wheel purchaser” explicitly stating (again) that the rim strips provided are not tubeless so they must have received a number of complaints/inquiries about not sealing when installing tubeless.
Had my first race on 25mm gp5000tl’s on hed jet6 plus’s. Seems like a really nice set of compromises, deep without being too heavy, good braking, puncture resistance, great rolling resistance, and comfy wide inner width/tires.
I have a few questions, first how much pressure should I expect it to drop overnight? I’m coming from latex tubes so I always check my pressures, but it seems like it’s almost 10psi.
I put in 30ml of sealant, which is the minimum. I’m thinking about putting in another 10-20ml for training, then pulling some out before races. Does anyone do that, or is it not worth the effort?
I think there are two types of rubber gaskets. One “gasket” seats in the hole and the other “o-ring” sits between the rim and valve stem nut. Not all valves have the “o-ring” but I’m pretty sure it nests inside the valve nut as there is space cut away for it to fit snug-ly.
I was about to say the same, pic from Enve video:
The tubeless valve stem should have its own built-in gasket, the Enve one is a substantial square block. Then put the o-ring on the outside, between nut and rim.
Threw on 25mm GP5000 TLs on my Giant SLR wheels last week. One tire went on fairly easy, but the second was super tight and probably took 30-40 min to mount.
I had no issues pumping up the tire with a standard floor pump and no sealant. Deflated, added 30ml Orange Seal, and re-inflated again with no issues. I’m guessing I didn’t need a compressor because the wheel/tire combination was so tight.
Did my first crit over the weekend, and while I couldn’t gauge the watt savings, the grip was fantastic and totally confidence inspiring (75psi @ 60kg). I can probably go lower, so going to play around with that in the coming weeks.
@russell.r.sage and @bbarrera are correct in their examples on the purpose of the OEM o-ring,
You need to look at the context of my reply (related to the post about cutting a chunk of tube out to make a homemade gasket). When you do, you will see my reply is accurate for the purpose of that specific situation. I added a bit of info to my post above for more clarity.
hard to say… most of mine seal up tight and maybe drop from 75psi to 50psi in a week. But some don’t seal as tight.
When installing or reinstalling, I put 40ml of sealant in. My Orange Seal came with a handy dip stick, and during the summer I usually check sealant level once a month. And every 3-6 months I’ll take off the tire and clean out any buildup.
Same here! First one I posted on a few days ago - super easy… second one, I broke two of the wide park tool levers, got some even beefier pedro’s levers, still no go. So either rim or these tires are wildly inconsistent.
Final solution included - new Giant rim tape on Reynolds Assault wheel (since the easy wheel had this already), tire next to wood stove all day to warm up, pedro’s levers to get as close as I could, a little soapy water, and finally - the kool stop tire bead jack (I think I read about it on here) and maybe the 30th try with that pulled it over the top. It had a long way to go - I couldn’t even get the final chord of the bead much past the inner side of the 41mm deep rim when the levers hit their limit - really didn’t think it would work, but I had already ordered it and figured why not.
HIGHLY recommend the kool stop bead jack for $13 - any prior tubeless tire that gave me a hard time would have been near-effortless with this tool. The Reynolds assaults also took an pretty scary load from this tool to get the tire on - this one Conti GP5000 TL was a whole new level of hell.
Good news is it inflated first try no problem - not too surprising given the insanely tight fit; held pressure fine overnight with orange seal. Can’t wait to ride them!
I’ve just converted 2 sets of wheels to tubeless for the first time.
First was on my gravel bike fitting Michelin Power Gravel TLR
The supplied rims were tubeless compatible which meant I had to tape and install valves, easy enough as I did that from new. Fitting was okay, a bit of soapy water and levers and they popped on, managed to inflate and seat them with a track pump, they slowly deflated over night.
Added sealant and they still deflate a bit slowly but only ridden them a few times.
The next set was GP 5000 TL to a set of new road wheels that came pre-taped.
Holy :rage::triumph::tired_face::imp:!!!
They were a battle.
Eventually using pure dish washing liquid and a thin, broad lever I managed to fit them.
Again inflated and seated with a track pump. Can’t comment on deflating as I added sealant straight away and have only ridden them once.
The one thing that keeps catching me out is riding at lower pressures, I look down and think I have a flat plus they sound different to tubes.
Conti gp5000TL on campy wto wheels - absolute knightmare to fit - had to resort to warming up the tyres.
Inflated with track pump though :slight_smile:
I was definitely spoilt with the mavic UST setup on my kysrium elites - they are as easy a tyre change as I could imagine. If I see my rear tyre is getting warn I will just swap front to back on a wim.
