Ciao all from Tuscany
I have a question about the relative accuracy of my VO2 max reading on my Garmin connect App. I have a SRAM Force AXS power meter and wear a Polar heart rate monitor. While I am quite fit for a 67 year old, own a bunch of KOMs for my age group, I’m suspect of a VO2 Max of 68, given my age. Would like to hear what thoughts are out there on this topic.
Grazie!
Yeah, 68 is crazy high at ANY age, not to mention in your mid-60s. Something is definitely off.
You have to input an accurate, physiologic maximum heart rate for this to be accurate. It cannot be based on a formula or just the max you see in your sessions.
I’d say it can be estimated rather than calculated. And when we estimate something rather than directly measure it, there’s some estimation error. That is, your actual VO2max could be (I’m spitballing based on some peer-reviewed lit that I’ve glanced through) +/- 10 mLO2/kg min from the estimate.
If someone is after the psychological benefit of having a high VO2max relative to their age, then what I would suggest is that if you’re above average, go celebrate. If you’re below average, realize that VO2max probably doesn’t measure the other ways you’re healthy, and also go celebrate.
I’m serious, here. VO2max is a one-number summary. In the general population, it can be a good proxy for cardiovascular health, and many peer-reviewed studies have shown that higher VO2max is correlated with lower mortality. If you’re using VO2max as a measure of athletic potential … it has limitations.
Do you have your max HR set properly? I.e. did you test it and then plugged it in?
Yeah, I do agree all you have said. Still, those formulas can help OP to estimate whether his watch provided value is anywhere near in ballpark.
I mean, if it is near or even off by 10 mL/kg/min, this value is still very high for his age. And if it is off by half, then something is obviously wrong and he can look into watch settings as others have suggested.
I made the mistake of selecting an “auto detect max heart rate” option on my garmin once, and at some point it changed my manually inputted max HR based on an anomalous high reading. So then my VO2 max reading started climbing and climbing, and it wasn’t based on my increasing fitness but on my incorrectly high max heart rate setting. I went back and turned that off….so check that your max HR is set correctly, and the “auto detect max HR” option isn’t selected on.
Well, this is all very good information. Thank you!
Using on online calculator, realizing it’s only an approximation, my VO2 max is 51. High, yet, more realistic.
Off by a lot for sure. Thanks for the FirstBeat chart.
As I noted in my initial question, I wear a Polar chest strap monitor. Believe it’s quite accurate. Thank you nonetheless for the Garmin info.
He’s right about the MaxHR setting. If your Garmin blips out for 1 second and records your max way higher than it is, which is common, it messes up your metrics.
Lol, I need to put on nearly 40kg to be average for VO2max with the formula; obese on the NHS chart ![]()
I would also make sure your weight is correct in Garmin connect. That can really mess up the calcs if it’s a value in lbs input in kgs for instance.
The excellent are minimum, not maximum values. Plus they are sourced from sedentary populations. You can be quite a bit above those values if lifelong active.
75% above?
The figure of 68 isn’t unheard of for people in their 60s. On right of curve to be sure, but not to be dismissed without further context.
As a singular data point I know someone who recently did a VO2max lab test. The value was the exact same as Garmin. It was also 68 at an age of 49 so way above that firstbeat chart.
Mine seems to vary depending on what solo or group riding Im doing. It tends to go up on solo rides (especially indoors) and down on group rides. The highest its been in the last few years is 75 but its down to 63 after a few groups rides over summer. So I don’t have much faith in its calculation for this 49yo. Even if it was near genuine, my handling lets me down anyway!
