Question about Goddard
I’m scheduled to do Goddard tomorrow and I have two questions.
First yoou need to know Im working out in ERG mode… On a vortex
But one this particular workout I wonder how you guys manage it.
  1. The 30 seconds ramp up at VO2max… They’re supposed to be form sprints. However when I do forms sprins eg very high cadence… My power output goes way above target. During the initial seconds I spin off the saddle at range varying between 150-170 RPMs which I can’t sustain for more than 5-10 seconds. And then back off on the saddle at around 120-130 RPMs for the remainder. But my intitial surge gets my power to around 250w while I should do only 136w to 153w.
How do you manage it? and secondary does it affects my workout?
  1. For the ITL I can do it at the prescribed wattage around 80-85 rpm but not for the full duration of the interval. Probably for half of it. I read on another thread the the prescribed wattage should be halved to account for a simple leg. Should I disable the ERG for this part?
If so is there a keyboard shortcut to do this?
Any time you do form sprints your power will spike as you accelerate the flywheel. I think it’s just the way it goes. This will be minimized if you use a low gear as the absolute acceleration of the flywheel is reduced significantly…
I do all my workouts in ERG mode and have learned to spin up on the VO2 max intervals without overdoing the cadence (keep it around 8-10 rpms higher). Works out much better if you keep your cadence under control. Good luck.
Really wish there was a way to do this quickly on mobile without going pausing the workout and going into into your sensor settings.
We have an open Feature Request for it submitted.
Any update on this feature request?
Nothing to confirm other than they have the request:
