Quadratus Lumborum strain - anyone else?
Came out of nowhere on Saturday. No warning at all. Absolutely crippling.
Did a two hour productive endurance ride on the trainer the day before, and other than a little residual soreness from some deadlifting a week or so ago no issues at all with my back. Now I can hardly walk.
Intense pain in lower left back and into the outside of the hip and side/front of thigh. I’ve seen an osteopath but it just seems to be a case of waiting for it to go away.
Anyone else had this?
I used to get them all the time lifting weights. Physio worked best for me using some soft tissue work but they also prescribed some exercises
  • banded clam shells
  • banded deadbugs (keeping lower back flat to the floor)
  • banded bird dogs (slow as you can)
That’s it really unless you have some underlying imbalances or whatever. It goes quite quickly, I used to have to abandon the current session, but I was fine for the next. Makes you focus even more on keeping a good brace position when lifting. Belt or no belt.
Oh and I use heat packs or baths. Seems to help.
Thanks will look at all of that when it eases.
I think the origins were the deadlifting but the soreness had practically gone when the QL struck. In fact before it struck I was planning some light deadlifting in the afternoon. Half an hour later I could barely dress myself. Bizarre.
Also, my wife suggested a hot bath but I fear I wouldn’t be able to get out of it again at the moment. Giving a hot water bottle a go and that seems to ease it up a bit.
Anecdotally, a lacrosse ball into whatever side the QL you’ve hurt is, will be a good relief. Even if it’s a placebo it works for me.
Likely just fatigued muscles.
If the pain is referring into the front or side of your thigh it is unlikely it is a QL strain. That would be point tenderness to that area - pain side-bending away, and maybe pain with lumbar flexion - especially if you bend forward and to the opposite side.
Referring pain into the thigh is much more likely to be joint and spine related - especially with your mechanism of injury (deadlifting before hand).
Also, the “crippling” type of pain - less likely to be muscular in the spine than a lumbar “strain”.
I would get checked out by a competent and thorough PT/physio
Thanks all for the input. This has gradually eased thanks to a couple of osteopath sessions, rest and stretching. I also randomly found some helpful stretches via www.calispine.com
Peculiar how these things can suddenly come out of nowhere.
The best massage device.
