My saddle on my trainer is just uncomfortable. I had an older Specialized Phenom then switched it to the stock saddle off my new trek.
So I’m going to try a new saddle, a FIZIK Tempo Argo. I know you often can’t return or get a refund if the rails are marked up. Is there a way to protect the rails while you are testing the saddle?
I’ve asked… most of the shops I’ve been to don’t. One does but you have to rent. That’s fine, but it’s really just to get you to commit money so you buy from them because the balance could be applied to certain saddles.
I’m finally taking this advice! Tired of using a heated spoke to brand the electrical tape I used to finish bar tape only to find it flapping in the wind a couple hundred miles later. Got some X-treme tape & I’m going to give it a try.
Had to hope in the way-back machine to find this post that originally gave me the idea.
@RydeRuff12 how did you like the fizik tempo argo saddle. I am considering it now. Currently on a fizik antares and it has been good but starting to think I could have a better fitting saddle. Was going to try the 150mm. I think my Antares is a 145mm?
Any feedback would be great.
