Power meters and pedal extenders
Hi.
I have been having an ongoing knee issue, so I decided this past December to go in for Bike Fit Tune ups on my road, gravel, and “trainer” bike. I decided to start with the trainer bike as it was the one I was using most frequently given the weather in the Northeast at this time of year. We made some adjustments, which unfortunately resolved the knee issue, but caused issues in adjacent soft tissue. So, I went back in for another adjustment this past week. Too soon to tell whether these are the correct adjustments, early indications are promising.
One of the changes made was to add 19mm pedal extenders to help my knees track better. This is all fine for the trainer bike, as I don’t have a power meter. I source the power from whatever smart trainer I have the bike on, currently a Kick’r Move.
My concern, my road and gravel bikes are using dual side Garmin Rallys (RK200 for the road, and XC200 for the gravel). After a discussion with Garmin support, I know that pedal extenders are not supported for two reasons (1) it will block the antenna/transmitter that is at the end of the spindle; (2) Could potentially lead to misleading power numbers because of some changes to how the strain gauge is deflected.
I am not very clear on how an extender will affect the measurement. Which leads to my next question.
I reached out to several power meter manufacturers (Wahoo Speedplay, Favero Assioma, Stages, SRAM/Quarq. All provided the same response, pedal extenders are not supported, they will import the values being reported. Leaving out Speedplay and Favero, how does a pedal extender affect the values being reported by a crank arm, spider, or spindle-based power meter?
Thanks
-marc
Most normal pedals have an allen socket on the ends of the spindles.
Most power meter pedals don’t. The ends are solid, and that’s presumably where the antennas are.
By using a pedal extender, you’re putting a piece of metal directly in front of the antenna.
Shane, Thank you. I look forward to your results. Hopefully I can use that as a guide as what I should expect once I change power meters and add the extenders. I realize my “mileage” my vary.
The antennae for all those won’t be affected.
The force offset shouldn’t affect a spider or spindle based power meter at all. Those are measuring the forces in a vertical plane. The pedal extenders are creating extra sideways force because they give your feet extra leverage from the crank arm.
I could maybe see it somehow affecting a crank arm based meter. However, there’s already similar sideways forces from every pedal, since they all extend to the side as a cantilevered beam. You’re effectively just lengthening the beam and the power meter doesn’t know the beam length of whatever pedals are used. Therefore, they must be measuring in a way to ignore or cancel out that force.
Try contacting 4iiii and Stages and see what they say. Worst case, you can buy a used one and try it in the trainer to validate it. If it doesn’t work out, resell for the same price.
Unfortunately, using a crank arm is not an option for two reasons. My road bike already has a SRAM Red crank. Neither Stages nor 4iii make a crankarm. Also, I want to continue getting left/right power. I’m curious to see if the pedal extenders will help resolve an imbalance I have.
Thank you for the idea. I can place the road bike on the trainer (and use virtual shifting) to get an idea what the Garmin Rally and the Kick’r Move are reporting for power over a few workouts and then do the same after I swap power meters. Then I will have an idea as to how much the pedal extenders will skew the numbers, if any.
-marc
I have the same issue and am going to try the Favero Duo Shi power spindles which insert into a Shimano Ultegra Pedal. They have a Q factor of 65mm, which is less than the 71mm with an extender on a Shimano pedal, but much more than the Garmin Rally pedal. If needed, my fitter would then add some cleat offset to widen the Q factor further. Power Meter City sells the Faveros, and I’ve read good things about them.
I’m curious to what you experienced? I have a set of Rally 200, and my fitter wants me to use 19mm pedal extender. I don’t really want to invest in a spider powermeter..
@Shanew50273 , you can’t use extenders with all the current pedal based power meters. The antenna is in the end of the spindle that is screwed into the crank arm. The extenders will block the antenna. I ended up switching to chain ring based systems (Quarq) that work with my SRAM Red/Force Cranksets.
Thanks for letting me know!
