@Bioteknik Ok could be (starts to high), but I think the reason I latched on to that being LT1 is that in the Pro riders table in the same paper a) it is ~275W, b) that is roughly what ISM coached athletes train at (with variability of course), and c) ISM has stated he uses LT1. It’s also possible I have not triangulated all the info from verbal snippets and figures to come to a valid conclusion.
The reason I pointed that one out was that I thought the power numbers would be closer to @Skeggis numbers, and I’m trying to make the point that you don’t have to stay away from tempo (medio in the INSCYD world) to “train FatMax”, and that if he strictly stays at that fairly low intensity I don’t see the FatMax needle moving without significant volume and time. Of course others made the point that any intensity leads to better FATox but I’m not convinced. I favor endurance and low-mid tempo near AeT.
Whether or not you buy in to the INSCYD model (and I know there are shortcomings), it is an attempt to provide a more accessible way to get at information we see in that paper (or any sports lab testing). Because you really only get power from INSCYD and the expression “max” is used, it’s easy to get fooled into thinking that fat oxidation at an INSCYD-derived FatMax of 190W (for example) is significantly different than fat oxidation would be at mid-Medio of 235W (.79-.82 IF). After all, they are 45W apart and a different “zone”.
But, it is not. It’s practically identical. The way to demonstrate that is to look at those ISM paper tables. The values 0.38 - 0.31 could be the end of the baseline.
Even if it isn’t you’re not going to get the message from INSCYD. You’re gonna think: “riding at 190W isn’t the same as riding at 235W…so I should ride at the FatMax zone wattage to improve FatMax”.
I argue that this is good for @Skeggis because he doesn’t have to soft pedal around at low Zone 2 (Coggan) and not get fast and wonder what happened. If you believe (enough of) their model, what’s nice is that you could see FatMax value move independently of “base” and “medio” zones on subsequent tests, so it’s potentially useful. But it comes across as a “train here to reduce fat ox” message and that’s simply not the case.
Is this the tweet you’re talking about?
I don’t think that what you’re referring to, but I’m old and the internet is hard
JK, guys!
