Old guy prostate issues
63, and my story: The past 5 years I was having elevated PSA, but it went down below their ‘alert level’ and would go back up the next year. Last year, it was the second year of it being slightly elevated after taking time off. Someone must have looked at the trend and suggested I get an MRI. It showed a ‘massive’ prostate. My local urologist pointed at his models and said it was three times the size of the largest model. He asked if I ever had problems peeing, or peeing a lot. Nope, not at all. Still, it was highly recommended to have it removed, but the surgeon wanted to wait for the biopsy results (That was March)
They suggested a biopsy. Biopsy was scheduled for April. Showed 4 out of 18 samples having cancer, and there was indications of nerve involvement. Suggested remove it right away. It was an 8 signifying some possible metastatic change. Surgery was scheduled for ASAP, and they waited for an opening, otherwise I’d be scheduled for near January (2025).
I had to get a PET Scan, and that was crazy, but didn’t show any metastasis. The PET Scan was scheduled for the 13th. That previous Friday I was scheduled for the 15th. Talk about quick. Had the Pet Scan, and raced through the process to get all the pre-op lab tests done. And Wednesday I reported to be sliced and diced. Turns out the Gleason level was a 7, but still not good.
The ironic thing is that the last time I stopped riding for the test, it was almost normal. Weird, so I was telling people to relax, my level was fine, and it was percolating the whole time.
Why I didn’t have any symptoms of having a gigantic prostate was interesting, but to have it so advanced was also distressing.
So, the moral is Get An MRI! The MRI is the best diagnostic test for BPH. Get A PSA Test! And don’t play the numbers game like I was. Yeah, it will go down if you quit irritating it, but that doesn’t mean there could be issues percolating.
I had a multiport procedure done, and it was a trip. A foley catheter for a month (no riding) and another month off waiting for the urethra to fully heal. The leaking, the pain, the whole diaper thing, it’s been a trip. Serious ED too, yeah. But I don’t have cancer!
Everyone said that BPH needs to be watched closely. It could develop cancer at any point. My younger surgeon said that cyclists seem to have a higher possibility of developing cancer because it’s so irritating for the prostate. shrug
Don’t take it lightly. One of my previous docs said if a man lived long enough it will kill them. Ironically he developed prostate cancer, had surgery, and survived fine AFAIK.
Prostate surgery is a brutal procedure, but dying of metastatic cancer is worse. So either it gets ‘lifted’, or it’s removed. But either way it has the possibility of killing you.
Glad to hear you got diagnosed and they got things treated in a timely fashion. Lots of good points in your write up.
It is important to note that BPH/BPE and prostate cancer can co-exist. They are separate processes and BPH doesn’t lead to prostate cancer but it can raise PSA, as PSA is a surrogate marker for prostate size. This is why PSA testing sometimes can be so tricky. MRI has helped but ultimately biopsy is the key.
Another important point you make is that lack of symptoms from a big prostate. This is very common. Some men can have a small prostate but a ton of symptoms while others have huge prostate and aren’t bothered at all. The bladder outlet and prostate have a lot of some muscle and if the pelvic floor is really tight you can get symptoms. This is why Pelvic Floor Therapy can be helpful for some men to train them to relax these muscles. This is also why Flomax/tamsulosin can help, it helps to relax these muscle but it doesn’t impact the size of the prostate at all. It also doesn’t make you make more urine (ie. it’s not a diuretic), but if effective it should increase the flow rate of your urine and help you emptying better.
Good luck on the rest of your rehab. The good thing with surgery is you get the majority of the worst of it up front and then slowly improve from there. With radiation, the treatment itself is easier but then side effects come later, often years down the road.
The whole area is rich with nerves and valves controlled by those nerves. BPH is not unusual for some level of CA, but yeah some men have BPH and don’t have cancer (Hence ‘benign’) (and some men don’t have BPH and have cancer) So I was unlucky, but I was 'playing the numbers and so was my prostate apparently. So BPH expressly has no cancer, otherwise it would be something like MPH? (Malignant Prostate Hypertrophy)?
PSA does not in itself detect cancer. There are men that have elevated PSA and no cancer, it happens. An MRI is the current ‘recognized method’ of checking on the prostate and determining its size and general condition. I’ve had rectal exams (one that nearly had me seeing stars) and no one ever told me that I had BPH. NO ONE.
Also the PSA test does NOT actually test for cancer. It tests for a blood marker that is emitted by an ‘unhappy’ prostate. Biking really tends to piss off the prostate. The pressure, the repeated ‘trauma’, and the prostate gets irritated. My surgeon said that there is some research that indicates that biking does tend to predispose some men to have BPH, and of that population, a certain number of men then develop prostate cancer BECAUSE they have a large prostate and are cyclists punishing their prostates, or do some other activity known to have unhappy prostates.
During the surgery, it is not uncommon for the nerves to be cut that go to the valve at the bottom of the bladder (and inside the top of the prostate), and also cut the nerves involved in erections and bladder urinary retention. (Not to mention removal of the Vas, (and other procreation necessary plumbing)
In the old days, it was expected that men would be both urinary incontinent AND impotent. With some of today’s robotic alternatives, it’s possible to salvage those nerves, and many men have some level of urinary countenance. My uncle (nearly 90 years old!) had the nuclear fix, and complained to me about the side effects. Yeah, the nuclear/radiation seed treatments had their issues. The seeds ‘migrating’ and being passed in toilets and urinals is kind of minor. (But they also used concentrated radiation in the prostate area, and that had a whole list of problems, but it was ‘killing cancer’, and killing a lot of other things too. I think the surgery was brutal, but the rad treatment seems so over the top, but it wasn’t surgery so there is that. In his time of treatment, they often nuked testosterone production because in the ‘dark ages’, they knew that some indeterminate forms of prostate cancer were sensitive to that hormone, and in men with higher levels of the mighty ‘T’, they could have raging prostate cancer happen. His other option was the normal surgery of the day (through the rectum/anus, and guaranteed urinary, and potentially fecal, incontinence. He is still furious that they ‘injected him with female hormones’, no idea about that, but his treatment team did what was common at that time: ‘Nuke Testosterone’. How things have changed.
ALL of my treatment ‘team’ was really surprised I was not symptomatic for the size of prostate I had. They said that many men find ways to compensate for the blockage, and/or show up in the ER, and their doctors office in a ‘crisis’ not able to void their bladders. My step dad died of a prolonged interval of blocked urethra from, ironically, the prostate surgery he had. (Due to the backup, his kidneys failed and other organs followed, sadly)
On to ‘post-op weirdness’, I was having incidents where my ‘junk’ felt like it was vibrating. (Really, seriously) It’s those irritated nerves reconnecting. Like post op, it’s amazing what I feel and what I don’t) I was given ‘a look’ bu my surgeon after he asked avout those vibrations. I got the idea that he was not impressed. I told him that the vibrations ended shortly after I started riding again. Yeah, the idea that the human male bottom on a bike seat causes erectile dysfunction is a solid yes for me. Eventually I could get past ED, but apparently my surgeon, and researchers, aren’t so sure. ‘Man’ do get it back ‘usually’, but there are no guarantees.
Would I want to give up riding for the ‘vibrations’ to return? Wow, an interesting question there… I’m addicted, like many are, to the endorphins. I need my fix! Maybe the side issue is GET FITTED? Make sure that nerve is happy. Before it was the prostate, now (post-op) it’s that damned nerve.
This is long, sorry, but I’m trying to go through what I have experienced, and hopefully (maybe) will remove some of the apprehension over getting a prostatectomy. (A local friend of a friend had a high PSA and had a bad biopsy, and is scheduled for surgery soon. Yeah, it’s frightening, but dying of prostate caner is no walk in the park. I’m still shocked at the number of people that have died of prostate cancer. It’s largely treatable and caught soon enough is gone. It’s worth getting tested, it’s important to know what the tests are actually testing, and also important to know what tests men should be doing (An MRI, to me is WAY more important to the snap of a rubber glove test)
I think that male cyclists have the possibility for BPH, and that BPH can lead to prostate cancer in unlucky men, and prostate status need to be taken more seriously. Get the PSA (WATCH the trends!, first time elevated, take at least a week off and retest. If still high definitely do the MRI, and followup from there), get an MRI, if indicated, get a biopsy. Life is still worth living, and ride on!!
Yeah to surgery ‘front loading’ the issue of having ‘had’ (hopefully) prostate cancer. (I have to have a PSA done every 3 months for the first 3 years, and every year for the next X-number of years, and then I’m ‘clean’.)
(This post fueled by killer pizza and Ménage à Trois, Silk, soft red blend wine)
“A doctor” not “your doctor”.
I see a lot of older men in my practice (primary care/GP). Tamsulosin is an effective medication but you have to be careful of the cardiovascular side effects. It can lower blood pressure (particularly if dehydrated) and can cause a reflexive increase in heart rate. LESS of a concern for otherwise healthy individuals, but anyone can be affected and outdoor exercise in hot climates would definitely be a concern.
My preferred alternative is finasteride. Does not affect blood pressure, works by shrinking the prostate over time, and increases hair growth as a nice side effect.
Keep in mind, all of the above is my professional opinion. I have no personal experience with either medication or BPH/PCa.
Hi Guys,
I went through my own prostate nightmare which stopped me from cycling.
I have since created a resource to help other men learn about Chronic Prostatitis and avoid getting Prostate Cancer.
I hope it helps you or one of your friends get thoroughly tested early and get back on your bike quickly!
Regards
Mark
ChronicProstatitis.Org
