Nailing VO2 Max Attack workouts
Need some group help people.
Currently coming to the end of my build phase. Getting a lot of vo2 max attack workouts. Examples are Peters and Opheim. Basically 6 2 minute vo2 max intervals with 4 sharp 6 second sprints per interval between 150-200%.
The vo2 portions are fine. I am struggling to spin up and hit the sprint target powers. I can’t meet the average power for the sprint as I am behind from the start. Of course I am using resistance mode as ERG cannot handle that short an interval. Any advice?
I have tried shifting up earlier a few seconds before the burst, but this bogs down the end of the preceding vo2 portion.
I have tried shifting and going all out right at the start of the interval.
Any advice for nailing such short bursts? Or do I just need to improve technique and rate of force development to hit those bursts?
I wouldn’t worry about the power targets or shifting. Just find a cadence that allows you to be reasonably quick on the VO2 Max bit and then rev your bits off for 6 seconds on the sprints :blush:
Make sure your trainer does not smooth the power readings before sending it to the app. I have wahoo and I turned it off from the wahoo app and it fixed the lags with short burst.
Firstly workout profile graphs set impossible standards, its not physiologically possible to increase power output by 100s of watts in an instant.
If i was doing this kind of workout I would spin up before I changed up to avoid getting bogged down. i wouldn’t worry about the momentary drop in power as I change up, we have to change gear in the real world and the higher the power we are producing the higher the cadence needs to be. I’d be aiming for at least 10-20rpm faster cadence while sprinting compared to my cadence at VO2Max.
I still use ERG for these, and while there may be some slight lag in getting your trainer up to the power target during the sprints, there is usually equal lag bringing it back down (we’re talking a second or two).
However you decide to do these, I wouldn’t worry about being to-the-watt perfect, as whatever you’re able to manage is likely getting the stimulus we’re looking for.
These are really hard workouts! :sweat_smile:
Second using erg mode for these. I personally wouldn’t even try these not in erg mode for that first part at least.
Just keep your cadence quite high starting a few seconds before the kick.
Yep, me too.
Never had isssues with ERG mode:
  • 0.5-1sec before big power jump increase cadence considerably (for me, it is about 130rpm). This way it does not hit you hard and can controllably lower cadence slowly for rest of interval (or not, I usually keep it up for ~15-20sec)
  • 0.5-1sec before interval end lower cadence again to sustainable level, so actual power drop will not make you spin empty
With the Elite Suito on short intervals it can get confused or something and ramp up the resistance within a recovery and/or suddenly release it when you are only half way through an actual interval. Before I got dual sided power meter pedals it was a right pain and I’d do workouts entirely in resistance mode, now it works more often and I’ll stick in ERG mode more. Although I do wonder about the last interval when I feel ERG is restricting me from pushing to max as I would have done with Resistance mode :thinking:
Thanks all for the help. I never considered erg mode for this kind of interval as thought the biggest was too short. Will try this with a big spin up before the sprint.
Yeah man why you make em so hard. Ha
So is the training we’re going for just to be able to hold vo2 power while still being able to surge repeatedly? Rather than making sure you got certain sprint numbers.
Think of these as a sort of over/under workout. Being able to kick while already riding hard is something that can be useful in multiple situations – especially attacking on long climbs.
I’ve been afraid of these workouts for 2 years due to how hard I failed some in ERG mode back then… I figured I’d give them another shot and searched the forums for advice & found this. Successfully completed one using this advice! Thank you! It’s nice not having to fear them or swap them out anymore!
Anyone had experience trying these workouts outside? Recommended? Better indoors on the trainer?
As others have stated I’ve found these to work fine in ERG mode as the delay in power up seems to mirror the delay in power down. For a pragmatic approach IRL, I’d look at these as the 6 seconds is getting up to speed simulating something like a very tight corner or a mistake made on a technical climb. Come to nearly a stop and then blast it for 6 seconds and then settle in to the vo2 power target range. That approach would be more geared towards mtb or cx though so if you’re a road or gravel rider then maybe the spin up ahead of time and then a couple shifts would be better. Let us know what you figure out to work best!
I think there’s a significant difference in ERG mode response time between trainers… I use the Tacx Neo 2T which reacts so quickly it’s like hitting a brick wall if you don’t spin up before the interval. Others might react quite a bit slower. In my case it actually made these super short hard intervals nearly impossible until I learned to control the cadence. My power would spike to 800 watts when it was supposed to be 600 and I’d start failing the intervals. It’s an issue that DC Rainmaker flagged with the Tacx Neo trainers ages ago since they don’t use a physical flywheel that naturally has some lag time.
