Small but suits my needs ![]()
How are you finding the Rivet?
It’s terrific
Here are my thoughts from another thread: Smart Bike Trainers in 2026 - #11 by stevo_bot
Thanks! Very useful info!
Hello,
Here is my setup: I’ve owned an Elite smart trainer for three years and wanted to add the other accessories from the range, but they were far too expensive.
Recently, I was lucky enough to find an Aria and a Rizer at a very low price!
Here is the result:
- Elite Direto XR-T smart trainer with Zwift Cog
- Elite Aria fan
- Elite Rizer grade simulator
- Zwift Play controllers
- 32" TV
- Old computer
- IKEA tablet/shelf
- Decathlon mat
- An old 2003 Gitane Mach 300 bike with Shimano A2200 components—which will never see the road again—stripped of everything no longer needed (front derailleur, shifters, brakes, cable housings, cassette, wheels, etc.)
Have not seen those pedals in years
I recently had ankle surgery. My foot is still very swollen, so I can’t wear cycling shoes; I have to wear wide sneakers, which is why I put these old flat pedals back on.
Are you me . Had the same issue at the beginning of the year. Broken foot . Had to go up 1/2 size in tennis shoes. I had to use spinning shoes for a few months. I’m just now putting on my old road shoes.
Very nice setup. Is that roll rubber flooring or tiles? I need to get back looking for some cost effective flooring for my workshop/office/pain cave. Thanks.
Thanks! These are 23" x 23", 8mm thick interlocking tiles. Here is a link to the product:
Nice set up - I was thinking about getting an IKEA table like that, as the Lifeline trainer table I have is just too big for my needs.
Also, you gave me some inspo for our spare room. We need to get a proper bed, and your hack is excellent for when you may need a “double” bed.
Thanks ![]()
Hi,
I think you should keep your Lifeline table; it’s much better. The only advantage of the Ikea table is that it’s cheap (€30).
It wasn’t tall enough, so I had to raise it by adjusting the leg extensions and drilling new holes.
I also upgraded it by adding a cable management box, a USB charging hub, and an LED light strip.
As for the beds, I’m lucky enough to have two guest rooms. This one is the “kids’ room,” with two small beds. Normally, I stack these two beds onto the double bed in my other room so I can put my rowing machine here instead.
Good to know! Thanks for the additional info.
My Pain Cave in the Hallway in my 1 bedroom house needs to be portable (I could make it more permanent in the living room but that’s a bit too warm). At the moment I’ve also got a Life line like table and would be looking for something more suitable to my needs but it doesn’t sound like the ikea one ![]()
I have a RAD cycle products desk which works very well and is pretty reasonably priced. It doesn’t fold but can be rolled out of the way.
Has anyone here build a rolling platform for their trainer setup so it can be moved around a space without much effort? My concern is then the stability of things if you’re being supported by just 4-5 caster wheels.
That sounds like you need … rollers![]()
My Wattbike has a lower frame with 4 sturdy feet but there are two castors at the front slightly raised. When the Wattbike is flat it’s fully supported by the 4 feet, but if you tilt it to about 45 degrees then the castors get engaged and it’s easy to wheel around.
Oh I see, in the UK I’d call that a dolly, rather than a trolley, so a sturdy platform on castors that you can lock off. Used by removal firms son I’d search for something like that
