They make hydraulic skates. Your platform needs to have room under it for the skate to slide under it. Might be overkill but worth a search in case they make smaller flat units that dont need to move a race car or heavy equipment around.
Have a look at these - Threaded Stem Leveling Castor
We use them on massive bits of kit at work. They have pads that you wind down and it lifts the wheels up.
I have a set up that I have to set up before and pack away after each work. I had been using a Lifeline/Rad type trainer desk. But that a bit awkward in my 1bed maisonett so I took a punt on this and on first impressions I think I’ve made the right choice. Some reviews said it was awkward to set up but they are completely wrong. Insert the centre pole into the already assembled base and bolt the desk to the centre pole and tighten two easy access bolts with the supplied hex keys. And it’s simple to use, one trigger to let you rotate the desk up into position and two clamps to adjust the height and legs. Its quite compact folded up and easy to move about which is what I wanted.
I took the day off and went out and met some mates 7.7miles from my house and rode with them to a cafe in Geddington and of course came back by The Falcon in Fotheringhay and ended up with two pints of Barnwell Bitter which I didn’t feel like I got out of my system till 6.20pm so I gave the local paceline a miss and tried out my new addition to the pain cave. The new table obviously isn’t quite a spacious as the lifeline/RAD copy I was using before but it’s much easier to set up and is ample for my needs.
I did some renovations on my pain cave this year. I need to finish organizing a few things better and take some photos to update this post.
Picked up a X-lab for the trainer so I don’t have to keep taking my gravel bike on and off it. DIY hedgehog rocker plate type thing to reduce long ride discomfort. Yes, the saddle is far too nice for the $ of the bike, but my wide seat bones like it.
Old TV means I can watch endless GCN, Unbound, or whatever else will keep me entertained while training indoors.
Few BMX trophies from US races just before leg surgeries to give me some motivation and remind me to spin faster - I can no longer stand very well to pedal after the knee op(s) caused permanent atrophy in the right quad and nerve issues so BMX is completely out of the question even at the relatively tame level of (older) women’s cruisers. Hoping to add some old photos and maybe some new race things to the walls in 2027!
Fits a banana! ![]()
+1 point for GCN on the TV. I enjoy there shows.
+1 point for slanted ceiling. I’m a sucker for upstairs rooms with slanted ceiling
+1 point for buying a dedicated trainer bike. Impressive.
Thanks! Cycling is the one thing I can still do with one weaker leg, although I’m never going to set records! I’m originally from the UK and GCN ride a lot in and around where I used to live so it’s nice to see a bit of “home” now and again.
