Hi all please could someone measure the distance needed from the wheel axle of a Kickr Core to the wall behind the trainer? Trying to plan a pain cave in a small space and not sure I can squeeze it in. Cheers!!
12 inches
Brilliant , thanks
Bored enough with the call I’m on that I just went and measured . . .
The rear leg of the Core is 12 inches from the axle so that is the absolute minimum axle to wall measurement. But you’ll need some additional room to swing your leg over the saddle and mount the bike in a normal way. unless you are very short or have circus flexiblity. I’m 6’3" and my rear axle is about 27" from the wall which is more than enough. I could probably go down to 24 or so before I had to start thinkning about the wall when mounting.
Forum crashed so this might be a dupe post
Brilliant I hadn’t thought about the room needed to get on the bike ! Thanks I will have a good think
