JOIN cycling app
Yes almost identical for me. Though mine is a one day event that is my main race. I did think it was extreme.m but I did a taper before my last race similar and I placed 1st and felt super fresh so idk
If I a have to guess, you are training Friday to Sunday on the previous week, which in Join terms means Monday off, Join always gives the 2 days prior to a race off, if your race is on Saturday there is only 2 days for workouts, if on Sunday you probably have 0 availability in one of the middle of the week days.
The 2 days prior to a race off they explained it’s to give the user the option to do whatever openers he wants, it’s not really intended to be 2 days off
Did you do more volume then previous years? Or is the only difference the structured guidance from Join?
Way more volume (almost double that of previous years) because join pushes you to do more (every Sunday a reminder). Even trainerroad’s high volume plan (which I never did) seems like low volume now
Ok, some maybe the gains are also just from the extra volume and not really the join structure. But ok, if this join plan helps you to do more volume, nothing wrong with it ;-). Curious if the Marmotte plan also works for La Marmotte (did it 5x). Good luck…
For that’s the case but I probably would never have done so much volume if join hadn’t steered my in that direction and gradually worked me up to it. In their podcast they always hammer on the fact frequency is THE most important driver of endurance progress, followed closely by total volume and with intensity being a more distant third
Whilst this point is generally widely accepted, I think what it really great about Join is they basically never give you a workout that you can’t complete. When there are intensity intervals, they build endurance volume around it. It also makes for workouts that are easy to execute outdoors, for example a 2 hour ride that has 3 x 10m pyramids in the middle. It’s like… intervals that a coach would prescribe by hand rather than built using workout builder software. This leads to consistency, increased frequency and volume. Sometimes simple is best. It may be lacking (or hiding) a lot of functionality, but I find pairing Join with intervals.icu covers every base.
(Context… had my first child so my usual race calendar doesn’t exist this year, so I’m doing a tour of the various training platforms and approaches. Currently on Join and so far I’m scoring it highly)
Would love to hear your ranking of the ones you have gone through so far.
I’ll report back once I settle with something.
@gloscherrybomb What’s your list for testing? (Want to see if I can add more to it :P)
Hi I’m going to have some problems over the next 2/3 months getting any sort of consistent riding in let alone any structure to it. When I get the chance I’ll prioritise group rides with my friends when I can get out for 3/4 hours but in between I’d like to fit in the odd hour or so either outside or in. I’d like these if possible to be the best option for keeping whatever fitness I’ve currently got. Any ideas as to what plan to follow? My thinking is to do the Winter Plan as best I can but am open to alternative ideas. Thanks
Any plans to tour Fastcats app?
Alternatively there is the indoor plan which is supposedly a higher intensity plan and as it uses workouts from the same pool I doubt it’ll be difficult to do them outside
Thanks i’ll have a look at that. i think the mention of the gym might have put me off
If you have zero structure week to week, I would just assess what I needed most on the day of the workout. If you did 3-4 hours with friends on Sunday and it was mostly SS, and then you had an hour on Tuesday, I would do 30/30s or 4x4 VO2 (and next time 5x4, 4x5, 5x5). If you have time again on Thursday, but know you’re going to do the spirited friends ride outside on the weekend, I would just do some Z2/3 work on the Thursday. OTOH, if you knew you couldn’t ride that weekend, then I would do Threshold on the Thursday. The point being, for me, if my time was super limited and I couldn’t structure "Tuesday is VO2, Saturday is TH, etc.), there would be no point in setting up a plan in an app that I knew I couldn’t come close to adhering to. That would just create unnecessary stress. YMMV.
So basically Train Now with TrainerRoad if I want to take as much thinking about it out of the equation as possible?
You definitely could! You could also just create your own in TP (or Intervals or whatever).
Simple is better in my humble opinion. When was I fastest? When doing mostly threshold riding and resting when needed. When was I strongest? When I adopted a minimalist program that doesn’t interfere with cycling.
I’ve been programming my workouts for a month and decided to give Join another try, on Monday I paid for a month. Monday it gave me cadence pyramid, but I did my own endurance ride (fwiw JoinBaseCamp really helped me figure this out once and for all). It then changed the Tuesday workout to 5x5-min tempo, which I figured was a good choice given the Wed drop ride. So I did the tempo work.
Not that I’m concerned, but for entertainment purposes I’ll post the analysis:
and
It gave me an 8.0 :man_shrugging: My coach would never downgrade his assessment over not precisely hitting 60-70% on the endurance work. Yes I read above that Join plans to loosen up on this aspect of ratings. No matter, I’m not looking at their score however I’ll say 8.0 is better than the 64% execution scorethat Garmin gave it. Again this does not motivate me and I don’t care because its shifting focus away how your body actually works to some gamified version of “perfection” in the absence of all other factors.
My personal preference, I would rather look at this:
and say to myself “mission accomplished” than get a 8.0 or a 64% or some other gamification score.
To each their own.
Yesterday (Wednesday) it gave me this:
and I gave it a group ride & strength training:
Friday it suggests 90-min intensive endurance (30-min at 70-80%). Saturday is 2 hour Tempo Steigerung, which is what I prefer to call progressive endurance. Monday is 10x40s(20s) and 4x10m(5) tempo, something my coach would have given me. Tuesday is 2 sets of 2x10m(10) threshold, and I picked the long climb plan which promised more threshold work :+1:
Still early but all seems reasonable, I’ll continue overriding some of the suggested and see how it adapts.
One thing I really appreciate - workouts have both power ranges and cadence ranges. Perfect for feeding the Garmin 840 default workout page :+1: Wish I could set the default cadence range for endurance, right now I export to TrainingPeaks and edit the endurance cadence from 85-95 to 80-90rpm.
I have a lot of positive experiences with FasCat, and look forward to playing with that in the future.
I also do this if I’m feeling good. Sometimes I’ll do extra sets, other times I’ll extend the duration of the intervals (like this morning - 2x20 sweet spot that I changed into 1x20 and 1x35). Tomorrow was a programmed day off anyway, but had it been a workout day then JOIN would have adapted it or given a day off.
You can “force” JOIN to give a workout (unless it is the fourth day in a row due to their 3:1 format) by playing with the Recovery setting. My major shift points seem to be at 50% and 75%, but others have reported theirs change at 33% and 66% - you just need to play with it.
Thanks for the tip, but I’m not going to game the recovery setting. Just feed it and see what happens.
Re: 3:1 yeah I generally support however I’ve completed 3 days of work and today planning a super easy ride (frequency first club). I don’t need an app to tell me what to do, just interested in how Join reacts and adapts to what I do (loosely aligned to their suggestions). I’d like to try the same with FasCat too. I’ve tried Xert a couple different times, it doesn’t seem to align with my philosophy, but I can see how it would appeal to some.
