Is it better to do a workout you may fail or do an alternative that you won't?
Over the last couple of months I’ve been in a base phase of my training plan, so lots of sweet spot and threshold workouts. I’ve had two instances of sweet spot workouts that have two 20 minute intervals.
The first one I cracked several times on each of the intervals. I finished it, but it was def a max effort and maybe got categorized as a fail (I don’t know if that’s something we can see or not).
There were several factors that led to the cracking on the intervals, the biggest being lifting the day before (I couldn’t adjust my schedule), but also I’m just that I’m not great at long steady state intervals. It’s something I want to improve on though.
I have been doing better at sweetspot intervals where it’s broken up into 10 minutes intervals:
So, today I see the stepped down version of the same workout with the 20 minute intervals on the schedule. My internal debate is:
I know I’m not great at these intervals and that I may crack during one or both intervals, but I want to try them because I want to get better plus this is the base phase so this kind of endurance is the point of the phase, so I should do the 20 min interval even if I might fail.
VS
If I switch to an alternate of the workout that’s 10 minute intervals I know I’ll be able to complete it successfully, so I should switch to an alternate so I can mitigate the possibility of failing the workout.
Today I picked trying the 20 minute intervals.
I did better, and it was a slightly toned down version of the workout, but I still cracked twice in the second interval. But yeah, I don’t know if this is better progress vs switching to an alternate with shorter intervals.
Any advice?
IDK, but I figure what matters is the amount and types of work that are accomplished. If I’m doing a workout and it’s too hard, I’ll dial down the power level. Sometimes it’ll be a little to be able to make it to the end, or I’ll dial it down a lot, recover some, and dial it back up. In a sense, I failed that workout and didn’t do as much of the types of work as I was supposed to. I figure that’s not a lot different than doing a somewhat easier workout that I didn’t have to dial down. So, my preference to try to do the assigned workout and if I can’t make it, dial it down as needed.
If you can do 10 minute intervals, but not 20 minute intervals, see if you can find 12 minute intervals.
Then maybe 15 minute intervals.
You get the idea.
If you can’t find them in workout alternates, search for them in the workout library. Or make your own.
What Helvellyn says is spot on, if this is your focus I would spend the next couple of weeks or so gradually building up to 2x12 then 2x15 etc.
One thing I also found useful in these scenarios if to turn ERG off, in my experience this removes the worry of the spiral of death and sometimes just backing of 5-10w or so for a minute really helps, more often than not having the freedom of no ERG meant that I completed the workout, over the course of the interval still hitting the required power target.
Totally. I do that in ERG mode. The left/right arrow keys on my keyboard decrease/increase ERG power.
My own experience is physically I cant tell what is better. Mentally doing a workout I can do is a lot more satisfying then struggling. You are good at 10min and you did fine on the first 20 minute. I dont think your far off but you could look for a workout at 15 minute intervals
A single workout does not matter. What does matter is the pattern / consistency over weeks, months, years.
If it occurs once in a blue moon; nothing to be concerned about. If it is a regular occurrence; a review of why needs to be undertaken.
I’d do the version you can finish. In base, what builds the engine is mostly total time at sweet spot, not how long each interval is. Four 10s gets you the same 40 minutes as 2x20 without the cracking. Then build up the way Helvellyn and Malcolm said: 12s, then 15s, then 20s.
A few things that haven’t come up yet:
  • Are these indoors? A lot of people can’t hold the same power inside as outside: no airflow, a locked-in position and a perfectly steady load. A big fan helps a lot. And TR uses one FTP for indoor and outdoor, so if outdoor rides helped set yours, your indoor targets may be a few percent high. Knocking them down a bit is fair.
  • Move the lifting. Lifting the day before a key session is likely part of it. Try lifting after your hard ride on the same day, so the next day stays easy and your legs are fresh for the intervals.
  • Fuel it. Have some carbs before and during a 2x20. Long steady efforts get a lot harder when you’re running low.
  • Break it up mentally. Think of a 20 as four 5-minute pieces, and spin a slightly higher cadence than feels natural.
A simple test for moving up: if you finish the last interval on target and feel like you could have kept going a few more minutes, you’re ready for the next step.
Another tip:
Occasionally, you’ll be doing, say, 2 × 20 at sweetspot and you’ll approach the end of the second interval feeling strong and think that you could continue at the same RPE for a bit longer …
… keep going - until RPE decouples. It’s a great way to find out that you’re ready for 2 × 30 or 1 × 45 right now and thus get a week or so ahead of the plan.
