Am I the only one who cannot develop same watts indoor as outdoors? I just failed an indoor woorkout, first one in 9+ months. I feel TR should be able to assign the right indor workout after having access to more than 1500 workouts with my indoor/outdoor power profile. Power meter is the same in all sitatuons.
1 failed workout in 9 months is a pretty incredible track record. Are you saying they have you failing less than 1% of workouts, and you’re complaining about it?
Indoor sessions can be brutal depending on the type of workout! Regardless of temperature or fans, a trainer’s flywheel offers a different sensation that makes high-intensity work much more challenging. I’ve found that using a larger chainring or smaller rear cassette spins the flywheel at a higher RPM, which feels much closer to riding on the road.
@BenB it’s a matter od perspective. You could also say I failed 50% of all indoor workouts in last 5 months.
Indoors I train in my living room which currently has around 22deg celsius. My fan is Vacmaster AM1202R and I have a window open. I’ll try using Velotoze Cooling Ice vest but that as much I can optimize my setup.
It’s like this for years and I see around 20W difference in indoor/outdoor FTP for most of the workouts. Shorter VO2max/anaerobic power seems closer but nope, not this time. I fear I have injured myself as I feel a discomfort in groin area since this failed attempt.
I just wish TR would offer a proper user feedback loop to accomodate what is seems a common scenario.
Yes, 8.8% increase seems nice but it will dillute in next 7 days, TR always overinflates the prediction. It’s not realistic at all, I would be happy if my real FTP is close to current 296W or 4.2W/kg.
Sorry @Mindflash , I misinterpreted your comment and thought you had a lot of indoor riding. It sounds like you recently switched from pretty much all outdoor riding to indoor.
I would guess you’re getting better cooling outdoor than you are indoor, and that’d be your main difference. I have my indoor area set to about 18C with 3 large fans blowing on me. I wouldn’t be surprised if your room started at 22C and ended at 25C by the end of the ride. I know you said you’ve gone as far as you can with cooling, but maybe see if you can get another fan or two blowing on you.
As you get a higher threshold, the heat problem gets worse and worse too. With a 300W FTP and a metabolic efficiency of around 25%, it’s like having a 1200W heater going the whole time you’re on your trainer doing threshold work (900W from body head and 300W from the trainer).
I almost always have issues on my first indoor workout after a while, be it after unstructured block, rest period, or a structured outdoor block.
I’ve also had the dual problem - performing much better indoors than outdoors.
In both scenarios the workouts seem realistic, so I tend to get quite frustrated with myself and/or TR. Anyway, when the dust settles, reflect on these:
Are you riding the same bike? I have a dedicated indoor bike with different fit than my outdoor bike. I had a 10 watt fit-related difference between the bikes
Are you using the same power source? If not, try dual recording to see how they differ. My partner had a whopping 10% higher reading on her crank-based Quark.
Do you approach the workout the same as outdoors? Warmups are quite different indoors and outdoors for me, also nutrition
Cooling and hydration. I absolutely need good airflow around me indoors. Even then, there will be a huge puddle of sweat underneath me. Hydration has to take this into account on longer sessions
ERG hits different. At first I struggle due to the lack of microrests, that’s why I think the first indoor workout is always a borderline failure. Also, I sometimes extend the rest between intervals outdoors due to logistics, never indoors
ERG hits different. No microrests but not going over target as well. In the long run I get better at sustained power indoors and as I close in on my limits for certain intervals, I can’t even complete them outdoors due to the power fluctuations and increased cognitive load.
I’d echo this - My indoor training space can easily bump up 4-6 degrees in the course of a 1 hour workout. And humidity commonly ends at about 80 percent. Starting at 12-14 degrees that’s not an issue, but if your start point is 22 and you’re ending at 26 degrees and high humidity then even with a huge amount of airflow, cooling is going to be a limitier as you’re just moving warm damp air about and evaporative cooling won’t be limiting your core temperature properly.
For the same workouts I can have a notably higher RPE or chance of failure in summer than I do in winter
How far apart do you think your indoor and outdoor power is?
The others are correct - its probably down to cooling - but there are a couple of technical device setup considerations that could effect power accuracy even if the same PM is used. So might be useful to share your indoor setup - PM, device used to run workout and what software is used.
Most people can’t, indoors has less motion and less dynamic air cooling etc. I deliver more longer term indoors (maybe because I’m not easing up for traffic etc) but on the shorter stuff outdoors is always more powerful for me too. First in 9 months sounds like TR are making a pretty good call on your performance though. My training is started to move indoors last month and I think my FTP was a little too high based on outdoors stuff but its sorting itself out.
