I am doing a polarized build block now. I see “AI Predicted Difficulty” for all workouts in the “AI training simulation” span, except for my long suprathreshold workouts. When I click on one of those workouts to see a detail view, I see a loading scaffolding for the difficulty prediction but then it disappears from the page when the request resolves or throws.
If you aren’t able to make the prediction for some reason then you should show that it’s not possible in the UI, ideally explaining why.
Thanks! I scheduled an over/under workout on the same day as one of those workouts, and it showed a predicted RPE, so this seems to be a visual issue with those Long Suprathreshold workouts specifically, as you mentioned.
could you clarify what you mean by visual issue? to reiterate, the problem persists when you expand the workout. there is a brief moment where the app is in a loading state as it fetches the data, but the UI is suddenly removed from the page, presumably when the underlying request fails for one reason or another.
Still having this issue. Feels premature to designate a message as a “solution” without some context is to what, if anything, changed or any related timelines.
