How to rate a failed workout due to illnes
Feeling under the weather and have a threshold workout on deck tomorrow. If I feel decent enough to try it but have to rate it as 9/10 on zwift or can’t complete it, how do I help the AI understand its sickness v the workout just being too hard? I’m fine with taking a rest day instead but don’t want to throw off future workouts if I decide to give it a go. Thx
This is one of the reasons I prefer doing the survey on TR rather than zwift.
If you fail a workout or give it a much higher RPE than expected you will be presented with a second survey asking for possible reasons.
Might be worth logging onto TR, finding the workout, and changing the response to “max effort” - you should then be given a second survey where you can select “illness”
Great solution. I’ll do that. Thanks!
If you fail or cut a workout short in Zwift, you’ll be prompted with a struggle survey when you open TR.
If you simply struggled and the workout was harder than expected, you might have to manually go back to that workout in TR and update your survey response to include your reason for struggling.
I’m digging in to confirm that second part. :detective:
