Help with my weird physiology
One way to assess this yourself is to map your 5 sec, 1 min, 5 min and FT power on the table in the link below. This will tell you where you are differentially strong (currently).
Great read, many thanks
I would do what Bryce suggested and do relatively easier VO2 Max workouts. All VO2 max workouts are not created equal. Something like Taylor -2 is a lot easier than Spencer +2.
Start with short on/off workouts, skip intervals in a set if you must, then build up from there.
Have you been doing a lot of VO2 work? If you haven’t, I suspect your FTP is so close to your VO2 Max power because you’ve trained it to be that way, rather than your body only wants to operate that way.
Thanks Nate, much appreciated. I think I’ve neglected VO2 in the past, and to be honest suspect I’ve just been bashing threshold meaning I’v adapted to that rather than anything else. Today I did Spencer at a power level suggested in a follow up phone call with the Boardman people and managed to complete the efforts, but only just, which I guess is as it should be.
I now have a plan, let’s see if it works over the coming weeks!
