Experiment with eating more carbs before, during, and after. On a 3 hour ride I may burn 2500 calories, which usually means I’m eating 50 grams before, another 240 grams during the ride, and another 50 immediately after. Call it 350 grams total. I’m still negative 1000 calories, which is a huge deficit. I would add an extra 200 carbs on top of my typical day to help make up for this deficit. That’s probably going to put me at 700-800 total carbs for the day. Since adopting this strategy my headaches and post ride hangovers have totally vanished.
You can drink as much as you want, if you don’t have the right minerals in store, you’re not going to hydrate. The human body doesn’t store any h20 in h20 form. It’s all crystallized/salts.
Caffeine, from what i understand, blocks the absorbtion of magnesium, which may often be a problem.
Um, what?
Same for me too, I was getting headaches, fuzzy vision and brain fog. However I will also add COOLING into the mix. Liquid, salt/electrolytes, carbs and a BIG ASS FAN. The Fan was the biggest piece of my puzzle.
not enough water consumed and not enough salt in the system.
I find that using Oral Rehydration Salt does the trick.
hydration. you can’t store water if you don’t have enough salts
You might need to read up on “crystallized”.
Counterpoint. How do your shoulders and neck feel after the session?
I find that I am more prone to tension related headaches after hard rides, perhaps because of how I’m gripping the bars or tensing my body. Core strength failing up the posterior chain to cause back tension leading to headaches that source from the trapezoid muscles.
Just a thought.
Good luck.
with Text Neck / Laptop Neck. After a ride it’s also worst off.
which was why I asked about the ShockStop Stem in another thread.
