Having trouble getting my tr workouts to push to wahoo
Everything seems to be connected because what one records, the other shows, but I can’t get the calendar or workouts to show or push to my wahoo bolt. Anyone have any secrets to share? Cheers
You need to switch the workouts that you want to sync to “Outside Workouts” by right-clicking on them.
You can also edit your plan to default certain days to outside if you’re going to consistently do workouts outside. :+1:
Has to be done on cpu not mobile?
Never mind, figured it out on mobile. Thanks
I’m having the same issue - the TR planned workout is not pushing to the Bolt head unit.
I set it as “ride outside’”
Are you sure you have your workouts set to outside?
What’s your TR username?
I got the same issue.
There’s a lot of small steps, linking one program to the other but the secret is to go to the “details” part of the workout, click the bottom left corner (different on desktop and mobile), click edit then it will open the tab that allows you to alter the details. Has to be set on outdoor workout and sync’s every day if you use wahoo.
There’s several steps but once you get used to it, not terrible.
Could you make sure that you’ve run through all the steps in the Help Center article below? Wahoo made some changes to how things sync a while back, and you need to make sure that you’ve got things set up properly now.
Also, open the Wahoo ELEMNT app, go to “Workout” > “Pick a planned workout” > and “Sync From Web?”
Then ensure that TrainerRoad with our old logo isn’t connected (there will be a checkmark if it is and a > if it isn’t). That’s for connecting to our old API.
I’m still having trouble syncing workouts to my wahoo element bolt device. Most of the time it works but sometimes it doesn’t. You’ll see a flashing wahoo symbol in the bottom right corner of the workout and if you hover over it it says “Syncing to whaoo…”.
