Feature request - failed workout due to heat!
What kind of temp did you have in your training room? I’m quite intrigued to know what temp heat training involves… and how it compares to my recent experience. Also do they focus on certain zones for heat training? I’ve just done sweet spot 7.7 in 32 degrees. Not fun
I think typical heat training is easier riding if you’re doing it on the bike. The heat puts it’s own stress on the body so adding a hard workout to it is tough
Other people do their workout then right after sit in the sauna or sit in a hot bath.
We had our a/c replace about 5 years ago and when they redid some of the ductwork I asked them to put 2 a/c vents in my room where I exercise including one directly over my head.
Yeah, proper active heat training is driven by core temp and/or HR.
Most often, the mechanical load is really low if you’re creating a hot enough environment.
After completing my workout (ERG mode, no pauses) my FTP prediction for 2 days away dropped. I wonder if my HR was elevated
Are you allowed to put film on the window? There’s a bathroom upstairs with a Velix window that I’ve put an opaque patterned film on, mostly for privacy but it has the added advantage of reducing the amount of heat from the sun. There’s some foil reflective film that might be suitable as well.
Every single one of you trying to do indoor workouts in this amount of heat - look into getting a window or a portable air conditioner. It’s sort of like working out at altitude, if it’s hot enough there’s just no way you can do as much work at higher intensities so you are impacting your workouts otherwise.
I use a small window air conditioner and it makes a world of difference combined with my fans.
“weather” might be the more broad one. Unexpected rain,ice, and wind also impact outdoor workouts!
Yeah I’m just too lazy to call up a window film company. Windows too big for the largest film I could find from any specialist. The AC works though except in heatwaves like this where it’s hard to get below 24c
Yes to this. In central Texas in my garage, it’s often 90+ def F with very high humidity.
I have some Govee sensors in my garage right where my trainer is. This morning’s workout felt harder than it should, even with three fans. 77°F temp, 81.5% relative humidity, and a 72.5°F dew point. It’s not necessarily the temperature making it harder, I think it’s the relative humidity and dew point. I don’t think my fans can evaporate my sweating fast enough, so I’m slowly getting getting cooked.
Dead on about the humidity. I have this issue more in the cold months of the year - it can be 60 degrees in the garage and I’m dripping with sweat like it’s the middle of summer with higher power or longer intervals because I can’t get it dried out. It’s actually easier for me in the summer when I can run the AC.
I’m on-board with TR starting to collect data about heat-impacted workouts (would be great to have this with altitude too). Not sure if it’s just a struggle survey, I could see having data beyond that being helpful to the models too.
Big puddles this morning under the trainer.. Looks like it will be this way all week.
Humidity makes a massive difference.
Consider safe sauna temperatures vs hot tubs.
That’s an extreme example, but temperature is temperature. :thermometer:
Would love to see some strategies for this in the podcast. It was almost 90°F in my garage last night. Three fans, lots of water and turning the workout down 6% got me through. I’ve had a couple workouts like this lately. Just sleeping felt like heat adaptation training.
Im fine with however the AI views this, and don’t need a way to lie to the system. I’m mostly curious how to get the most out of those sessions and not die. Do I need a mini, New England summer heat block in here each late May and what would that be?
Is there a rule of thumb for how hot is too hot? I.e. at what point should you stick to zone 2? My garage is 31c, due to get warmer over next few days. I’ve just done an hour of Z2, sweating buckets, 2 fans just moving hot air around
Like stated above . It’s not so much the temp as it is the dew point/ humidity factor . I just got back to Texas from a few days in Reno. Although the temperature was nearly the same, Reno was much more tolerable. At times 85F felt chilly there. 90’s we’re fine.
It’s like RPE, it’s individual judgement.
I’ve raced Ironman in 30°C+ So I can do hard work but that doesn’t mean it’s a great idea to train in it.
London right now, I’m thinking an easy spin at most outside, with enough fans and darkness the Fortress is Solitude can be better, and less risky…but mine flooded last night in the thunderstorms! Doh.
Yeah I’m on the coast, south of london. 35c in my garage … the fans just move the “hot soup” around
laughs in floridian
