Export indoor training to Garmin
I am using the Beta TrainerRoad app. How can I export an indoor planned training to Garmin for outdoor usage?
You’ll need to sync your TR and Garmin accounts and set that workout to Outside. Simply right-click on the workout in your calendar and switch it to outside.
Here is our Help Center article on pushing workouts to Garmin.
Let me know if this helps!
Thanks for your quick answer. How can I change the workout to outside on iOS? I know how to do the with the website, but it is unclear how to do that with the app.
Found it! I have to edit the workout and change it to outside :slight_smile:
It also syncs super quick. If you change it, force Garmin to refresh, you should get it immediately in the training folder of your Garmin.
I like to dual record (Garmin for pedal dynamics monitoring a hip issue) and so I do that, load the workout on Garmin, then edit it on TR and load it on the TR app for more accurate indoor power settings. Works a treat and I just have to delete the second recording that shows up in Garmin.
