Endurance Rides - Why so uncomfortable?
Whenever I ride any prescribed endurance rides, I find it really hard to rate them and I think the AI is confused with my actual ability.
I’ve recently ridden at a solid 200w for 3 hours whilst away in France, felt comfortable, but on the turbo it just feels… hard.
Even a 1 hour session at a 180w average, I don’t really feel like its ever truly easy… my breathing is easy, my HR is low… but muscular feeling is moderate. Does anyone else get this because I mark moderate, then the AI reduces my future FTP predictions.
I can’t tell if I’m just bad at zone 2 wattage on the bike haha! I can hold my actual FTP for an hour, on the turbo and outside on the bike… so I feel like my FTP is right, but I just really find turbo endurance work painful!
Is it supposed to be like this, or am i just weak :smile:
On the turbo are you in ERG mode? If so, that’s likely the reason. Riding outside your legs get micro breaks since its essentially impossible to keep power perfectly on target for the whole ride. In ERG mode there is no variation, your legs are locked in for the entire duration with no variation at all. Its the reason why ERG mode workouts tend to count for more actual training stimulus per minute than outdoor workouts.
Also, even if you could keep power perfectly consistent outdoors, the way the bike moves underneath you spreads the muscular load around your body differently with more variation.
Yeah. I got a rocker platform to help with this, and it does somewhat , but still nowhere near riding outdoors. Outdoors, all the varying movement and sensory stimulation makes it easier mentally and physically.
Are you using two different Powermeters, say the one on the Turbo vs Your bike?
If so are they reading about the same?
TLDR for trainers inside, but Endurance can be worse due to low force.
Gearing & Flywheel Inertia: Make sure you consider what gear you apply since lower gearing = lower flywheel inertia. This can be rather different than the experience outside actually rolling with real mass. Many people aim for mid to higher gearing on the trainer and even at max it often falls short of what real inertia outside is.
Motion (or lack of): Rigid trainers are evil for most people, particularly for rides at 60 mins and beyond. Full motion like I use (E-Flex Plus) is great but even the most basic motion with things like thick foam blocks and such can transform a terrible rigid trainer into one with a moderate amount of movement. Per my saddle pressure testing (vid if you want a 30 min boring sleep aid) even a minimal addition of movement can have a notable reduction in saddle pressures.
Fans: Cliche, but make sure you have one or two REALLY good fans. Even at lower power output, the fans help with cooling and fatigue.
Standing breaks: Make sure to include regular standing breaks. These get overlooked often and part of it is the odd nature of standing on a fixed trainer. Even with the mild motion I suggest above, it still feels weird but should be added as a regular part of your riding. We do it naturally outside for many reasons, but it gets forgotten inside.
Gearing 2.0: I like to use higher gearing and lower cadence frequently (60-70rpm), to increase the actual force on my legs. This has a side effect of reducing saddle load vs higher cadence that is more common in typical training. So mix in different gearing and cadence not only for your actual muscular load, but also saddle load.
Yeh I use ERG purely to do exactly what the prescribed workout is. How forgiving is TR AI if I don’t match the power target exactly (say… free ride in Zwift then match workout?), i’ve never tried it.
I am, Wahoo KIKR and a favero assioma pro rs-2, I’ve tried the pedal on the turbo and seems to be mostly 5w or less discrepancy, so I can’t even blame it on that :smile:
So… will I ever get used to it because it’s been like this for years, really puts me off endurance rides on the turbo.
I have a rocker plate and my fit is pretty spot on, don’t really get any issues saddle wise etc.
In regards to gearing, are you saying it helps to be in the smallest cog on the back then?
Rereading your post something else occurs to me that I missed at first. I don’t think that just because your muscular exertion feels moderate that you need to mark the ride as moderate. I did a 3hr Z2 ride yesterday that had a few endurance plus stretches of 20-25 minutes. 25 minutes spent at 74% of FTP definitely doesn’t feel like an easy spin but I still marked the ride easy because I know I could’ve done it again. But at plenty of points along the way my legs were definitely working.
I would get very familiar if you’re not already with the RPE instructions and not worry so much if your quads are feeling the work for endurance rides.
As a secondary point, maybe focus on muscular endurance training specifically.
Cheers, I’ve got the 1 to 5 RPE thing someone posted up… it’s really hard to tell if boredom and position fatigue is making me mark these workouts as 2- - moderate, or they’re actually easy and I’m just hyper focussed in my legs not ‘feeling easy’ compred to lungs and heart.
I’ve rated most of my endurance rides as moderate and it’s not until today that the endurance ride I did ‘felt’ easy. But also, after marking several endurance rides as moderate, TR popped up with a message telling me to run AIFTP detection as it thought there was an FTP discrepancy, reducing my FTP from 320 to 306.
I don’t want to game the system but I’m unsure as to whether I’m confusing the AI :smile:
The brain is fickle. At any effort level, it’ll fool you into thinking you’re riding too hard and should back off slightly.
Normally you can motivate yourself past that, but at endurance pace indoors, there’s no motivation to be had.
I totally get that! I try not to game the system for a false benefit but I do sometimes game the system in the sense that I know better than the AI does. Again, use with caution of course, but there are times when I just know myself better than the machine does. I know how hard of a day I had at work and I know how hard of a day I will have tomorrow. Again, I’m very careful with this because even if you have other reasons for fatigue or whatever else the fatigue is still there and you have to let the AI account for it. But sometimes there are circumstances that don’t really fit inside the available levers to pull and you have to take the wheel.
I’ve written somewhere else about how my red line for endurance rides is; doI want it to be over physically? (not mentally… boredom is just a thing with long endurance sometimes). But if I’m physically over it and just kinda want to stop its an automatic Moderate no matter what other stories i’m telling myself.
FWIW I have my training approach set to Balanced but Endurance and Sweet Spot are set to Demanding. These 2 zones i find are both great for muscular endurance so my muscular endurance is pretty dialed in and I might therefore be having a different experience up at the top of Z2. You might try experimenting with that.
I think you’ve kind of hit a part of how I feel about the endurance rides, for example I did Colosseum -3 the other day and it should be easy, but I’m riding it and thinking to myself ‘if this is truly endurance, surely this should be an absolute doddle, so why do I want it to end’.
I think in my head, endurance rides shouldn’t be even scratching the surface, but actually should probably give them more credit.
I don’t think it helps that outside, I’m the sort of rider who likes to get out the saddle, not because my fits bad or because I’m struggling, I just like to, it feels good.
Either way, I’ve had an FTP reduction and I’m going to run with it for the next 3 weeks until AIFTP prediction day… see what the endurance rides feel like.
Agree. No breaks make it feel different. I usually rate my 1 hour endurance on the trainer as easy. I could double the ride if I really had to, even though the legs notice a slight weight or slight fatigue at about 45-50 min. If I had a 2 hour endurance ride scheduled on the trainer (haven’t seen that yet), I’d make sure I fueled up better and it would probably not get an easy, at least where I am now.
If I have an indoor endurance ride on the schedule, I never do it in ERG mode - I will free ride in Zwift and just make sure I am in the general ballpark.
My mindset is that when I do endurance rides outside, I think of target power as a range so why not the same indoors? And I have more fun doing endurance rides on Zwift as free-rides anyway, the changes in terrain/gearing/using a Robopacer etc keep me more involved.
Did it all of last (Canadian) winter, regularly around 2 hrs and TR AI had no issues with it that I can tell. I definitely can’t blame that for my FTP drop this summer (bronchitis on the other hand… :grin:)
Is it the same bike? If different bikes, maybe your outdoor bike setup allows you to make more power.
Yes, if your goal is to get the most flywheel inertia and “road-like” feel from the trainer. “It depends…” of course, but higher flywheel speed on the trainer more closely matches real road bike speed outside… broadly speaking. If you feel like the current action is damped to dead vs what you feel under foot outside, max gear is worth a try at the very least.
Just an update… so with the new FTP (after trainer road AI prompted me to check FTP and reduced it by 7w) I did an over under threshold session (Ishika) as per the my plan.
It felt moderate, I could have doubled the session… so I rated moderate. It’s changed predicted AIFTP in 25 days from 325 to 333.
I think me rating these endurance rides as moderate is having a significant effect on my suggested workouts/ planned workouts and after today’s ride they’ve all increased in difficulty significantly.
I’ll report back in a few days after my sweet spot session!
I started doing this for a few weeks a while back, probably even before the big AIFTP update… are you saying you free ride and then match the workout after you’ve finished to the prescribed one on the plan?
If it’s not mega close, how does it react? Do you get any messages or big aiFTP sways after linking the workout?
Lots of good advice above, and in many past threads. Once you have cooling, position etc… sorted it comes down to mental toughness. Once I started doing 3 to 4-hour endurance rides on the trainer, shorter rides seemed really easy. Goal this winter is to push that even longer.
Another tip for long rides: change your bibs midway.
