Hi all,
quick follow-up, I decided to give the ICAN Aero 50 Plus a go. If anyone is curious here are my thoughts. First the box was in excellent shape and the wheels were well protected with foam bad plus the entire insert to keep the wheels in place was also foam so a good start.
So the build quality looked very good, spoke tension was even and the bearing and pawls were all properly greased with light grease. The wheels were true both laterally and horizontally.
The 23mm inner width and almost 31mm outer fitted with my GP 5000 in 28C makes for a very smooth transition between tires and rims. So the setup should be decently aero.
The wheels are surprisingly very stable in crosswind and quite predictable. The hubs are also very smooth rolling. The wheels are actually not too harsh and quite compliant. They are also quite stiff laterally.
My only negative is that the 6 pawls freehub design seems fairly draggy when spinning the wheels on the bike stand but on the road it seems ok. I also don’t like that you need to unscrew the endcap to remove the endcap and freehub. Overall hub/bearing are most likely average but to be expected at that price point. The rims looked extremely well made with a modern inner/outer width. The CX-Rays spoke are also very nice for the price and easy to replace as they are readily available. I also like that the alloy nipple are external and the the holes in the rims makes changing spokes easy.
For the price, they are an excellent choice and customer service and shipping were very smooth. Definitely recommend.
