Does Garmin currently update VO2Max from sync'd TrainerRoad workouts?
Hi all,
This is a topic that’s adjacent to several posts previously, but I’m still a bit unclear.
I have TrainerRoad and Garmin Connect connected, and workouts are syncing well.
I’m curious if my Garmin Forerunner will update my VO2Max in light of the imported TrainerRoad workouts - does anyone have experience with this working/not working?
(Somewhat relatedly - I also wonder if the Forerunner will update my eFTP based on imported TrainerRoad workouts)
Cheers for any input
In my experience, my Forerunner does update my cycling VO2Max when I sync after completing a TR workout (automatic sync to Garmin Connect)
Not so sure about eFTP, I usually set that manually after my FTP changes
Same here. I did a hard workout last night and my VO2Max in Garmin Connect increased after syncing. on eFTP I can’t comment, not using it atm.
Yes, my Forerunner 245 (so a pretty old one) updates my VO2Max from either Zwift or TR workouts - I have not ridden outside with power for absolutely ages so it is the only way cycling VO2 is getting in there at the moment!
