The longer FTP tests are best, but if you want to get one done quickly, the ramp test is ok. One thing - don’t stand at the end, that’ll over-estimate FTP - keep seated and at a reasonable cadence.
I’d guess you’re true FTP is 210-230 (but just a guess). Let us know when you’ve done the test.
When I read OP’s op, I thought it was elaborate satire at first
On higher progression levels & effectiveness: at least if time to exhaustion is relevant for your training, long intervals certainly are the way to go. In most endurance disciplines that should be the case.
Also, I kind of recall that the duration for which you use a given energy system impacts the adaptations you trigger.
