AI FTP drop despite all main Progression levels increasing, Train Now
I have been using Train Now for the last few years as my work schedule doesn’t allow me to stick to a structured program. My overall goal is to maintain or increase my FTP for the foreseeable future, I turn 59 yo in January . I usually manage at least 3 1hr suggested workouts per week.
Over the last month my AI FTP dropped from 245W to 244W.
During that time I achieved my best ever 30 minute (243W) and 60 minute (212W) power numbers.
Here are the numbers for my last AI Detection period.
I wonder if there is an obvious explanation for my drop in FTP.
Would appreciate any advice.
Cheers in advance Chris B
I am surprised that you didn’t get a bit of an FTP bump after progressing to level 5.8 on threshold.
If I were you I’d send a message to TR support and see if they can try and explain.
They will have access to your training history so will be able to explain the logic or see if there is a problem.
Edit: skipped over the part where the OP was using train now not a plan… the static FTP makes more sense now
Thanks, I’ll send a msg to TR Support
Here’s my last few months data for AI FTP Detection…
So its generally went up from the summer :clap: but for the last two tests (AI FTP D) its stayed practically the same (I wouldn’t call 1 watt a drop) and I wouldn’t be worried about hitting a plateau in the short term, most folk do. If it becomes long term you may have to develop a long term strategy to get round it but lot of folk just naturally hover around it (the plateau) and just get better at holding their FTP for longer.
I am fine with hitting a plateau or dropping slightly, I just felt the PL changes this month would have resulted in an increase.
I’d try and beat it in a ramp test
Mentioning the sprint workouts got me thinking. I’ve just finished my third year of using Trainer Road and don’t think I’ve ever had a single sprint workout assigned to me. I’ve always done 16-ish week programs (never Train Now) and usually do two of those per year. From memory, I’ve done programs for XCO, short track XC, XC endurance, and fondo. I guess it’s normal to not have sprint workouts assigned in any of those programs?
For the record Coggan had the same privilege as any other user here. His time here was his own choice, by ignoring the multiple opportunities that TR gave him to correct his negative behavior and remain a positive contributor to the group.
why are we sweating an AI FTP drop of 1w? the reality is with a 30min best of 243 (assuming maybe a time to exhaustion of 35min), your ftp might be right or a little lower at 240w if you can’t make it past 30 at 243.
A 30 min best doesn’t mean that’s all he can do in 30 minutes, it only means that’s all he has done.
Yup, it’s a Progression Level not a Projection Level. :wink:
well, the best predictor of performance is performance itself, if OP wants to test they can try and keep it going for 35-40mins
I’m quite happy with the variations in my FTP . Also the 30 min and 60 min efforts I mentioned were not full gas , they were just the result of Train Now suggested workouts.
I made the post because my PL’s made me think I would have an FTP increase this month.
Thanks for all the replies.
As I’ve tried to explain ( possibly not clearly enough ) I was just intrigued as to why my FTP had gone down this month.
If anybody’s still interested here is a quick summary of the previous month
My FTP went up from 241 W to 245 W
Progression Levels were ….
Endurance 3.1 to 2.5 -0.6
Tempo 2.8 to 4.1 +1.3
Sweet spot 4.2 to 6.1 +1.9
Threshold 5.0 to 5.3 +0.3
VO2 Max 5.9 to 7.0 +1.1
Anaerobic 4.3 to 3.4 -0.9
Sprint 1.0 to 1.0 No change
Looks like the AI algorithm stuff makes it a bit difficult to guess whether your FTP is going to go up or down based on PL changes.
I think I’ll have to do a regular ramp test or 20 minute test to see if I’m working ‘hard enough’ to maintain my FTP.
Cheers Chris
I have become very suspect of AI FTP. It is what it is. I am would not be surprised if there are limits built into the algorithm that have nothing to do with actual performance. Just keep doing the work - looks like you are seeing improvements across the board. Best of luck!
AI ftp is a black box, only TR will know what causes it to re evaluate things and update your ftp.
The best indicator of performance is still performance itself, to get a true indicator of FTP it’s best to go test it out to at least ~40m.
That’s not saying you can’t get close with other methods just that they have drawbacks.
And let’s remember that progression levels are a made up system that helps TR prescribe the “correct” workout from their library. It isn’t like there is published research that ties progression levels to FTP.
