So, I have put 4 decent rides in on my new 1x road set up. I noticed the last conversation on here about it was a while back. Tech has changed. So I figure its time to revisit the discussion.
I have two road bikes. One has a Shimano Ultegra DI2 11 speed with a 11-28 cassette. I have ran 52-36 and 53-39 out back. Never really had a problem climbing. The 39-28 was a push but never felt like that was the problem. I also have a Sram bike with a 50t up front. 10-36 out back. 12 speed. Interestingly the same gear essentially for my easiest compared to the 39-28. I find myself grinding a little more on the one by.
I have two major questions. 1st off, has anyone done any testing on if big jumps are actually bad? The shifts are noticeable but is that a bad thing? I get in our heads it might not be ideal. But race day performance, dose it actually effect us?
Second, the way things are going, with tech. Has 1x just became the new version of the OSPW for those of us who fall for marketing. Or do yall think that there might finally be a time when 1x is just better? (Crit Racing aside where no one uses a small ring)
I did a 1x road conversion, just to check it out. 50t with an 11-46 (I have hills here).
It worked, but barely.
Perhaps it’d be different with more chainstay length, but overall the drivetrain was real unhappy outside of the middle 5-6 gears. Brand new freshly waxed chain and whatnot.
Maybe if you have drastically longer chainstays, it’d be better but the whole drivetrain shifted so much nicer and was much quieter as a 2x, it’s hard for me to believe it was working well.
Big jumps didn’t bother me in general, I’ve been on a 1x MTB setup long enough.
Nope, there is nothing bad with larger jumps. Both setups cover the same gear range. In fact, you could have gone with a 48-tooth chainring if you wanted the same top gear and a slightly easier climbing gear.
Let’s look at the facts: SRAM’s 10–36 cassette has essentially the same jumps as an 11-speed Shimano 11–32 cassette with an extra 36-tooth cog attached. Both have 4 tightly spaced cogs at the top and feature similar (≠ identical) jumps. (I used to have a Shimano 11–32 cassette on my trainer on the previous 2x road bike before going 1x.) For the easy gears, the gear jumps are smaller than on SRAM’s 10–33 road cassette.
Whether you prefer larger jumps on the climby end of a cassette is IMHO a matter of taste. I very much prefer them (I run a 10–33 cassette on my 1x road bike now and I used to run a 10–36 cassette when I lived in mountainous terrain), so I prefer SRAM’s gearing options over Shimanos. But that’s just me. If you ride the bike the way it is now and you are not noticing anything you dislike, then you are overthinking things.
Larger cadence jumps are something you get used to. I come from the MTB side where you have larger jumps on average anyway.
I‘d say if you’re not aiming at a world title in 1hour tt it probably doesn’t matter. With shorter chainstays you can feel the increased drag in the 52t cog but it won’t stop you climbing that steep pitch. Like bike weight this is mostly in our heads and whether you want to live with 1x on the road or not comes down to personal preference.
Edit: Bad example. 1h TT is probably primetime for 1x. Especially if it’s flat.
As with everything, it depends. If you can find a tight enough cassette with the top and bottom gears you need, then no. From personal exprience, on the odd occasion I’ve done hard sessions or fast group rides on my all road (when it had 11spd 38 x 11-42), it was not ideal but it was possible.
Have also dabbled in road racing (11spd 46x11-36) and that was fine.. but then the gearing was crap if I wanted to goto the Alps. Certainly wouldn’t go out of my way to remove a functioning 2x groupset on a best or training bike.
No, there are many upsides but maybe I’m just the sucker? I have 5 bikes and only 6 front chainrings..
But again, wouldn’t ditch a functioning 2x groupset for 1x.
I used to live in the Japanese mountains, and 1x12 would make that possible. At the time I ordered my bike, XPLR hadn’t been released yet, so I opted for a 10–36 cassette coupled to a 42-tooth chainring. That worked quite well. Would I have liked another gear in some instances? Who wouldn’t With the release of SRAM’s 1x13-speed groupset, I think this is a solved problem now. The range is as large as anything you can get on a 2x road setup and the large steps on the climby end would likely be a feature to me, not a bug. (I had even considered Rotor’s 13-speed drivetrain, but was discouraged by someone in the bike industry.)
Unfortunately, I no longer live close to mountains and even my 10–33 cassette offers too much range. It is exceedingly rare I use my 33-tooth cog When my chainring wears out, I’ll replace it with a larger 46-tooth one.
I have a 38-tooth chainring on my mountain bike (as I told you, it’s FLAT here), and I can keep up with road bikes cruising for a while. due to more aero and tire drag, I’d be doing sweet spot instead of Z2, though.
The jumps don’t bother me too much. But I agree that it gets finicky at the top and bottom and much prefers being in the middle. Which is where I spend most my time anyway.
GRX-812 derailleur into Tiagra shifters for my setup.
I would call that a very small amount of pros when you figure total race days. Is there any team riding 1x on climbing stages of any grand tour? My guess would be no. I recall the 3T team doing it because of sponsor desire and it was a failure.
In general, I just don’t understand why people want to ditch their front derailleur. Front derailleurs have never been a problem area for me.
1X doesn’t save any weight. It’s a wash when you add a heavier cassette and longer caged rear derailleur.
If one lives in a flat area, then no problem. Me, I’ve never lived in a pan flat area. I want my short chain stayed road bike to be a racer and not a cruiser. I want those short precise shifts.
If you don’t mind me asking, where abouts? Have been plotting a route through the Alps area, touring between Kyoto and Nikko. Might drop you a message it you know the area?
On topic, I’ll have 2 small panniers and hope that GRX 12spd 40x10-51 will be spot on
If memory serves, some teams even tried 1x12 XPLR setups. With 1x13, I don’t think there are many compromises, the 10–46 cassette is essentially a 10–36 12-speed cassette with the 36-tooth cog replaced by a 38 and a 46-tooth cog slapped on the back.
It was a failure, because SRAM hadn’t released a 12-speed drivetrain at that time. Nor was there a Classified hub or many cassette options. If you can’t fall back on 2x, that’s a dealbreaker. (I own a 3T Strada with a 1x12 drivetrain, so I know and love the bike.)
Nowadays Pros could run a 10–46 13-speed cassette with no compromises as to the range and road gearing for at least the first 11 gears.
It also isn’t an issue in hilly and mountainous areas either. The range is there, the jumps between gears as small enough. Plus, you don’t have to shift in the front.
(I lived in Japan and could cycle from sea level to 1,700 m above sea level. The mountains were higher, but with a road bike you don’t get farther than the parking lot of the local ski resorts.)
Drop bar bikes are switching to 1x, slowly. It is starting in the gravel space and will migrate. I expect that as soon as SRAM has released cheaper 1x13-speed groupsets and Shimano got off its rear end and released its new 1x GRX groupset with better cassette options.
One state on the sponsor’s super duper aero bike is simply a promotion. I never said that riding 1x is impossible or even a problem but it is not the preferred set of tools for a grand tour rider.
We’ll have to disagree on this. Even with Sram pushing 1x over the years, I see no across the board trend towards 1X for road racing. One stage here and there doesn’t count.
Omloop is a flatish race with short punchy cobbled climbs. I can understand Trek trying a 1x setup for reliability. But Trek is not showing up in the Alps or Pyrenees with 1x. Nobody is.
SRAM is agnostic when it comes to 1x vs. 2x, their solution is to offer both. I never thought that SRAM (or some other sponsor) was forcing the riders’ hands, my impression was that some teams and riders have been willing to experiment. (That’s the way it was written up and I have never heard rumblings like after the failed 3T sponsorship where riders were very vocal after the team had imploded.) If it flatly wouldn’t work, then these would largely be one-off things. In my mind, seeing 1x or 1x + Classified hub-setups are becoming more common.
Define “preferred set”: 1x is utilized and it seems to me that it is getting more and more common.
Let’s bet a dollar that in 10 years, the majority of road race bikes will be on 1x. What I see has all the signs of the adoption of disc brakes on drop bar bikes: people who grew up on the old stuff complaining, saying “the old stuff is easier to maintain” and “the old stuff works great, we don’t need that new stuff.”
My prediction is that 1x will take over in offroad dropbar bikes and TT bikes first, i. e. the next generation of TT frames might not be compatible with a front derailleur. Once, 1x13 becomes popular (by releasing more affordable options) , it will make inroads into the regular road bike market. Shimano will bring out one last 2x groupset where the front shifting is impeccable, but nobody cares. That is, history will repeat itself for the third time.
Gearing wise, you want an adequate gear range for the range of gradients, and close enough spacing in the higher gears for rides where aerodynamic drag dominates and power required goes as the cube of speed. 1x, 2x, etc. offer various tradeoffs between weight, aerodynamics, complexity, and reliability that are chosen among based on the situation and personal preference. There is no right or wrong.
I think we are already seeing the 2x die out on gravel. Look at the new Allied. No place for a front derailer and none of the video’s I watched even mentioned it.
Yeah, It was a comment related to bikes slowly turning one by. I was stating that we are already seeing it on gravel and it will have taken a hold on road soon.
