1 By For Road convo again
@AJS914 wanted a very specific example. It isn’t just one race. Let’s see what happens in the big races this year, specifically whether SRAM’s 1x13 drivetrain will be used more often.
For specific races with e. g. flatter course profile or where chain retention plays a role, going 1x seems quite popular. Given Shimano’s sponsorship dominance, it might be that more teams and athletes would like to try it, but can’t. (See also power meters.) In contrast, SRAM offers both, so teams and athletes can choose.
There is significant overlap between the categories these days. BMC’s new Roadmachine has clearance for 40 mm tires: Is it an aggressive endurance road bike or a gravel bike? The clear answer is “Yes!”
I think customers who get used to and come to prefer 1x might want that on all of their bikes. So trends in the gravel bike market will influence the road bike market.
People decide that 1X is the technology for them and then need to defend the choice on forums. It’s confirmation bias. They even see trends that nobody else sees. There is clearly no trend towards 1x in the pro peloton. There are a few examples on flatter stages and one team (3T) where it was a complete failure.
Just for the sake of debate what does 1X solve for high performance road riding? It eliminates the front derailleur (a problem???) in favor of a larger rear cassette and larger jumps between cogs. There is no weight advantage as it’s a wash.
For this person, 1x sounds perfect.
I’ve never said that 1x isn’t workable or can’t be adapted to or that riders couldn’t live within the limitations. For many situations it can be perfectly fine.
But, I still doubt that it is optimal for pro cyclists or even categoriezed amateurs other than some flatter stages, crits, or TTs. If it was, it would be in widespread usage.
Several come to mind, e. g.
  • Better drivetrain efficiency on TT bikes due to ridiculously large chainrings (which are no longer compatible with FDs) or
  • Any race where chain retention and reliability is important.
A couple of edge cases - definitely not taking over the pro peloton. A front derailleur actually holds a chain to the chainring pretty well.
I don’t think anyone claimed 1x is taking over the pro peloton. There is always nuance in statements, especially from OreoCookie. It helps to read carefully.
I can see how 1x on the road could be better for many people - especially “normal” hobbyist cyclists. 50/34 with 11-34 for many people is overkill imho and a 40 chainring with 10/11-44/45/46 would be a better gear range for many.
I don’t understand why SRAM didn’t merge XPLR with the mountain range. Would be so much easier to just have one derailleur and multiple wheelsets with different cassettes. I ride XPLR on the GRoadbike and I’m still confused about it - jumps are too big in the small cogs and the range isn’t much different from 2x.
Amen, I’m fairly sure most of us have been ahead of the pro peloton on many things for years too (tubeless, disc brakes, etc).
Also agree that most road bikes stock gearing isn’t suitable for the rider. For many, a nice 1x groupset is going to be the best option but not always.
To suggest it might be the new OSPW, put me in the disagree corner.
Yeah, that’s a big one that would simplify matters a lot. The shifter is electronic, so you’d just have to tell it what cassette it uses. It’d then also change “behavior” from Transmission mode (= prioritize shifting under load at the expense of shift speed) vs. faster shifts (= shift behavior of SRAM Red E1 1x13).
SRAM made that mistake when it first introduced AXS, the “standard” rear derailleur was officially only rated for a 10–33 cassette and for the 10–36 cassette you’d need to buy the WIDE rear derailleur. The “upside” of the standard rear derailleur was that it supported the 10–26 cassette, a cassette that was so unpopular that it was unceremoniously killed off. Standardizing around the WIDE RD would have saved me a lot of money back then.
Also, I think there is too much space between the 10–36 and 10–44/10–46 cassettes. Rotor had a 10–39 cassette with great ratios (= 10–33 12-speed cassette + 39-tooth cog) or alternatively a 10–40 cassette.
I also wonder what Shimano is doing when the new 1x12 GRX drivetrain is released. The 10–45 cassette has IMHO terrible ratios, not just for MTBing, but especially for groad/gravel bikes.
Out of curiosity: 12-speed or 13-speed?
Ultimately, that’s what matters: what do customers want and do companies offer products customers want?
12 speed. I wanted Ekar originally but after trying it out at my LBS I decided against it. 13 speed with a 48t chainring would probably solve my “issues” with 1x on the road but I think I’d consider going straight to 10-52 with an even bigger chainring for efficiency. Why I didn’t do that back when I built up the bike I can’t remember. Some mistakes you have to make yourself I guess.
I can’t help but think that 13spd MTB has to be coming pretty soon - hopefully it’s just a software upgrade and a different cassette and they merge those two derailleurs into just one. I’d buy the 10-46 for my XC bike and the 10-52 for the Gravel but XD casettes aren’t compatible with XDR freehubs so I’m just sitting on my mechanical XX1 until the industry has figured out how to merge their offroad offerings into one streamlined product.
I was briefly considering it as well, but I don’t really like the thumb shifters. Plus, at least on the demo bike I once rode, the brakes were not, hmmm, great — or set up correctly.
My 1x gravel bike is my road bike 99% of the time. I have a nice road race bike, but I hardly ever race road anymore and I like to train and ride on the bike I’m racing. And the gravel bike is way more comfy and plenty fast for group rides. 44 ring in the front and 10-50 (or 10-52) in rear. Plenty of range for anything. Easy to push 30+mph in the 44/10 and nice bail out climbing in the 44/52. Big gear jumps are fake news, all in the head…
I still like 2x on my road race bike, but I think it’s a mental/comfort thing more than anything. A 1x setup w/ 48 ring and 10-46 would be a solid setup for racing. For general riding/training I’d probably run a 46 or 48 ring with 10-52 even on a pure road bike. I have no plans to upgrade my road group or build a new road bike in the foreseeable future. And I’m not sure if I’d go 1x or 2x if I was building a road bike right now. It would certainly be a debate.
You should do a little more research.
Drivetrain efficiency is measurably worse on a 1x since you’re essentially cross chained at either end of the cassette.
You should do a little more research, nobody is at top/bottom of a cassette for a TT, always in the middle handful of gears.
These threads always devolve into using edge cases of edge cases to prove a point.
Maybe a good time to merge to the 1x mega thread.
TT bikes are an edge case.
The only issue with these threads is that the proponents take it on like it’s a religious issue. The love 1x and so should everybody else. They present trends that don’t exist and make claims that 1x will take over even though there is zero evidence of that.
I’ve actually been planning on converting my Crux to 2x. The 1x is fine for gravel but the gearing sucks for mixed surface events. 1x13 would cost me a small fortune but 2x11 can be done for like $150.
The only issue with these threads is that some people are way too emotionally invested.
OP asked if
anyone (has) done any testing on if big jumps are actually bad? The shifts are noticeable but is that a bad thing? I get in our heads it might not be ideal. But race day performance, dose it actually effect us?
And yes, some of us have done testing and testing has been done in the lab. 1x is less efficient in certain gear combos due to suboptimal chainlines on either end of the casette but can be more efficient in the middle of the casette (1x TT for example). Gear jumps annoy some people and some don’t care.
So ride whatever feels right to you. No one is trying to convince „the other side“. This is not politics. Let’s not always revert to „them“ vs „us“. Things are much more nuanced in the real world. Let’s not forget about the civil tone this forum usually has.
We’re here to learn and share ideas. Not rile each other up and divide us. In the end we’re all cyclists. Just ride what you want - no one cares all that much. Happy day
I assume when they launch the new force group, it will have 13sp xplr option. And eventually rival as well. I’m still a fan of the wider range mtb/mullet approach, but the 13sp is pretty sweet if you can live with the limited range. I’d personally like 13 that goes 10-52, but it seems they are set on keeping a line between gravel and mtb and I can’t see then adding another gear to transmission in the next year or so.
My favorite thing about my Ultegra 1x12 is I have “6 OEM buttons” I can assign to do whatever I want. My 52 x 11-30 is perfect for me!
Just one last comment before I bow out: I think what some are conflating are the statements “There is a clear trend for dropbar bikes going 1x.” and “1x is right and should be the preferred solution for everyone in all circumstances.”/“You should prefer 1x, too, because I do!” I was only arguing the former.
There are trends I don’t like (e. g. the move from pressfit to T47), and I think I can give arguments why I think it is wrong. But I still admit that this move is happening for the majority of the bike industry.
In a recent interview with Gerard Vroomen and Andy Kessler, they said that on gravel and groad bikes 80 % of the sales are 1x, for instance. Seems like we are beyond the tipping point in the gravel market. And manufacturers have started offering 1x configurations for their endurance (g)road bikes like BMC’s Roadmachine.
Yup. When SRAM started offering 1x, they had 11-speed drivetrains. There, you really had to compromise to get e. g. 420 % range, that was MTB gearing, period. The 13-speed 10–46 first 11 gears are functionally identical to a Shimano 11–32 11-speed road cassette. That’s quite a different proposition.
Like others have said, SRAM should offer more XPLR gearing option, e. g. merging them with their MTB gearing (their RDs are modular now, so maybe you’d need to change the rear cage in case that’s necessary). Or, alternatively, offer 10–40 and 13-speed 10–36 cassettes in addition to the 10–46.
No way people in any mountainous area will buy 1x.
What is far more likely to happen (because it would actually help consumers) is more customizability when buying your bike, i.e., you will be able to choose 1x or 2x when buying your bike, hopefully along with crank length and handlebar width and stem length and maybe some other stuff.
But claiming there will only be 1x road bikes in the future is laughable.
Adding a couple more cents to the subject of terrain vs jumps between gears, there’s a 15 km stretch of very lumpy highway about 30km south of Hobart, Tasmania, where I used to live: Channel Hwy between Kettering & Gordon if anyone wants to look closer at the example. Loads of very short, steep ascents followed by short, steep descents, with no flat road in between, rinse & repeat. The last time I cycled that way I was on the fool’s errand of trying to keep power & cadence within zones, & I was basically yo-yo-ing from one end of the cassette to the other & back again, with a few chainring changes. Using a road cassette was very fiddly, & in this edge case a wide ratio cassette on 1× with bigger jumps but the same range as my 3× would’ve been welcome. I say this as an avid multi-chainring afficionado. :laughing:
So yes, there are situations where bigger jumps between gears can be beneficial in their own right, not because it’s a side-effect getting the same range from a 1×.
