https://thegravelride.bike/chris-mandell-sram-zipp-rockshox-and-the-new-xplr-gravel-line-up
Really good to finally see the clean Reverb AXS dropper post come to 27.2mm.
Not a need, but absolutely a want!
Wondering if @Nate_Pearson would ever ditch an aero bike (and the requisite non-round seat post) to get one of these for a road setup and lower cornering position? ![]()
Meh…
1X Only
Additional complication and maintenance of seat post and fork
Overkill for all gravel races or rides I’ve done
If I need the fork or the seat post I’d rather be on a mountain bike anyway
At this point there’s so much overlap in bike styles/components, this seems redundant. I feel like once I’m to the point of using a suspension fork and dropper post, I’m on a hard-tail MTB anyway.
As far as 1x and the new gearing, I am not sure 1x is for me, but this new cassette at least makes sense for what I would want. Full mullet (10-50/52) was major overkill on the low end, with bigger steps than I would want. So the 10-44 is the best that SRAM offers for what I’d use.
Well 1x from SRAM makes sense, they can’t make a FD to save their life…
I agree a ‘Gravel Suspension Fork’ is unnecessary.
I do want the post though, but not for the reason MTB’rs run droppers. I’m 6’2" and if I could get lower on descents I’d pick up considerable speed.
If SRAM is reading this. Add hidden buttons to the shifters to control my Garmin and I will be buying a complete drivetrain setup and dropper post.
If Shimano/PRO is reading this. Make a Di2 dropper post in 27.2.
From what I heard in 2019, there were two version of this seatpost being considered – one that was marginally lighter and one that was much, much lighter. It looks like they took the marginally lighter approach. Kinda bumms me out
That said, running the 75mm version with an ultralight shim in an XC bike with a larger diameter seat tube is definitely the wireless weight weenie approach.
I really think the head design on AXS Reverbs is far from optimized in terms of weight. Functionally, it is the easiest to use and most reliable seat post head of any dropper I’ve used, but in an effort to make it work so well it seems they didn’t focus too much on weight savings.
If they could drop some weight from the head of the post it would be a huge weight improvement.
The 101 wheels seem to be a major flop IMO.
$1800 for for a 1600+g box section wheelset? I see ZERO reason to buy them over the 303S or 303 FC
I’ll be ordering the new detailed and big gravel cassette this week. I’ll still be running 2x but now have gears to spin those steep climbs.
The dropper posts are hilariously short travel but I guess most gravel bikes don’t have MTB sloping top tubes. I run a 175 and could go longer still lol
I’m interested in this as well… but Do you think we could use the new cassette in a 2x setup?.. knowing the traditional Sram FD difficulties…
I was going to say, “the $2500 Enve G23 wheelset disagrees” but it’s a lot lighter. These would be aimed at rocky trail adv bike/ bike packers, but the weight limit is also low and those bikes can’t handle rocky terrain well anyway. Looks like they are just trying to throw something out there. They would have been better off rebranding the Roam rims.
I like they went flat-top chain compatible with an eye toward sharing wheelsets with a road bike.
What weight range would you consider attractively light for an electronic dropper? While the head seems mass-ive, I’m not sure that much more than an ounce or two could be dropped (majority of weight being inherent in the actual dropper post itself).
In terms of marginal stuff, it sure would be nice if sram could make a half size batt, that would fit the same charger/mount base. Assuming that the power demands of the elec dropper mechanism are less than a derailleur.
The battery is actually pretty light. It’s not where the weight comes from. That said, I didn’t swap my battery after 6 months of use and it still wasn’t flashing red, so I’m sure they could make the battery smaller and save a few grams.
In most droppers the weight comes from the internal components that are in the post, but the AXS is a different beast. If you hold an AXS Reverb, it’s very top heavy. The head of the post is extraordinarily heavy compared to other droppers, and the weight distribution of the AXS is very different than a normal reverb and any other post I’ve felt.
I don’t know why droppers need to be built like a suspension component. It seems an overcomplicated solution to me and I think we could build a much lighter solution that way. I really like the direction of the new Fox dropper that focuses on being lightweight. Just a simple spring.
Return of the Gravity Dropper ![]()
Those were lethal, but dead simple and light IIRC. A proper modern take (like the Fox) with a reasonable blend of tech for better return damping, along with infinite positions seems like the future ideal.
I don’t get the road dropper post desire. I do a heap of my steering/keeping my bike stable on descents with my hips.
Maybe I’m just doing it wrong.
Dropper on MTB 1000000000% every time.
It’s possible to sit on the saddle in the dropped position, especially so in these case with only 50-75mm drop. I even do it on my MTB plenty of the time. Doing so will lower the rider center of mass which is seldom bad for cornering (i.e. nearly always the best thing to do in fact) and still give the control aspect of saddle contact.
As mentioned above, particularly tall people may be the ones that could benefit the most.
I’m 193cm and although I don’t really ride road these days, I’ve done a couple long fast road descents on the MTB and it felt less stable with the saddle down
I’m big into the Lee Likes Bikes doctrine and have really improved my descending by focusing on getting low. It doesn’t feel right on the tarseal though without locking my hips into the saddle.
As you say, maybe the trick is just the 50mm mark.
ETA: I can absolutely see the benefit on gravel where you want to let the bike float under you (like on a MTB) to maintain traction.
I’ve bene riding mullet this year (10-50). Took me a while to get used to it but so far it’s been great. the 50 saved my ass in a race a couple weeks ago. It allowed me to stay seated up a steep sandy hill and not lose traction. But I agree, I like the 44 option. When I put on the 50 I moved to a 42 up front, but a 40-44 low gear should be sufficient for almost everything.
The thing I don’t understand here is the post. Who is going to bomb into a rough stretch of road, realize the need suspension, and then work to drop the post 1mm so they can still pedal? Weird.
Ooh, we have very different gravel experiences… ![]()
