Woodway Treadmill Question
Question for anyone that might have a Woodway. I just picked up one used (2018 Woodway 4Front).
Everything seems to be working great, but even when the treadmill is off, the inner cooling fan seems to be running. It only actually goes off when I flip the power switch (as opposed to turning it off on the control panel). Anyone know if it is normal for it to always be running?
Yep it’s normal! I have a 4front as well.
The power switch shuts off the connection between the dedicated circuit and the treadmill.
This, manually, avoids potential damage between the power supply and the treadmill motor.
A Woodway rep told me that best practice is to turnoff the power completely following each use.
Hope this helps :slight_smile:
Awesome thanks so much!
