last season, I did 2 vo2 workouts a week, with the intent of not “overdoing it” and it was good,I definitely did not overdo it. but this time around I’m doing 3/week, based on the work of other people I know I think there’s a lot to be gained with 3/week, and my hope is I can achieve a fraction of what they achieved. I just finished week 1 and so far so good. the 3min stuff wasn’t my best, esp considering the 4min stuff was essentially the same. Gonna do 4x5min, 6x4 and haven’t figured out the third yet (will def do 5x5 next week). anyhow, here are screenshots of the sessions, these are done on resistance mode with my garmin controlling the trainer, I keep it set at 40% and it seems to give me the right gearing to do these
Chiming in a little more than 4 weeks post VO2 block. My FTP has gone up maybe 10 watts. Which, for my not-amazing FTP is ~5%. I shouldn’t complain, but for how brutal the VO2 block was, I hope there’s another few % in it for me in the next few weeks…
I know you already know this, but it deserves to be said, 5% in a month is MASSIVE! Congratulations. I can tell by your comments you earned it!
I’m vain… I really really want to pass that 200w marker!
I’m sure it’s been discussed earlier in the thread, but how long are you all giving yourselves to recover after a block before assessing for any FTP increases? I’m planning to start a VO2 Max block in a few weeks, and was planning to have a week and a half after the last workout of recovery before doing a long form FTP test for an initial assessment, but I’m wondering if it’s worth waiting longer before testing and using the workouts in my next block to gauge when a test might be worthwhile since it can take a while for improvements to materialize.
Maybe do something in between … a 2 × 15 ‘feeler’ workout. First interval at your old FTP (assuming you have a good number and know what 15 minutes at that power should feel like) and then the second interval at your “target” FTP.
If the RPE for the second interval is reasonable, that’ll help you calibrate for when you re-test a couple of days later. If it isn’t, maybe give it another week and try again.
At worst, you’ve done 30 minutes of threshold work. ![]()
I took a real rest week then another week or so of ramping back up, then did 2x20 when I felt fresh. Tried to just feel threshold, which gave me a new 20 minute record. I did a 3x16 after that which confirmed it and then tested, just to be sure. I was greedy and tried to aim higher in the ftp test. Bad idea. Don’t do that.
I’m curious, 2min intervals with shorter rest period and higher power are pretty good at getting you there, why aren’t ppl using it more?
after doing 3 and 4min efforts last week, i did 4x5min yesterday. the last time i did similar session was in July
and while my max power isn’t really higher at the moment (although technically it is by 2w on my best interval lol) yesterday, and this whole block for that matter, I am experiencing less fall off in power in the later efforts, so my overall 5min avg is up 8w from 332 to 340, we’ll take it
Because 3-6 min is better.
I use 2-minute intervals as a maintenance dose for my older masters athletes or as a second day of a back-to-back for people doing a lower-dose VO2max block. That’s just to get the work in in manageable dosing for them since they probably did a bunch of 3-min intervals the day before. Part of proper VO2max training is getting up to a really high O2 uptake and then staying there. I just don’t use 2min intervals much.
Hey @kurt.braeckel I’ve been having trouble getting my VO2 max to budge and am thinking about the nuclear option. When you do the three workouts in two days, are you doing the same interval sets for all? For example if I’ve built up to 6x4, would I do that for all three workouts? And do you expect the power to drop over the workouts, or do you hold back a little on the first so you can finish strong?
I won’t speak for him but you could do 6x4, I know some who start the week with the longer durations and do 3min efforts at the tail end of the week. I think you have a lot of flexibility. Based on my convos, you’d def expect to see drop off across efforts, each should be as hard as you can make it, so that’ll naturally decline
Lord no. ![]()
Before you go the nuclear option, have you tried just a regular 3x 3-week block of the high cadence VO2 intervals? Emphasis on the high cadence, like 110rpm with “fish out of water breathing” as your goal? Becuase if it’s just going out and doing 6x4 in the “VO2max zone”, that’s not really VO2max training. Not to say it’s not good training, just that there may be less stressful ways for you to push VO2max up.
What’s your overall volume look like? That’s the other consideration. VO2max will move with peripheral adaptations that come with a lot of endurance volume.
If you’re hoping to push VO2max up by riding 8hrs but doing 3workout in 2 day blocks, that’s not something I would recommend (Note: I know zip about your training history, so just making statements here).
All that being said, most of my concentrated VO2max blocks I decrease individual interval length over the course of the block while holding or building total interval time.
With the “nuclear option”, I do the longest intervals first, then the afternoon set on day 1 and the set on day 2 are shorter. This is to allow the rider to complete the maximum amount of work in a fatigued state. So that might start with a 4-5x4 in the morning, then do 6-7x3 in the afternoon and 5-7x3 the next morning. I like the “range” of intervals in these instances because it allows the rider to tap out when they KNOW they’re cooked which is critical when you’re doing huge loads like this.
There’s a lot of micromanagement that goes into VO2 blocks. Not to play gatekeeping coach here, but be cautious and really pay attention to your body and your metrics (on bike and off) any time you’re doing these concentrated doses of VO2max work.
Absolutely expect some power deterioration over the course of the workouts, but it shouldn’t be massive. If you’re doing them right (repeatably all out) you’ll see a decrease inside each workout, but every interval average should be over threshold by a good amount. My guidance for my athletes is if you hit an interval where you can’t keep power above threshold while doing that 110rpm for a good portion of the interval, you’re done for the day. Then we evaluate why that happened. More often than not, it’s just an overspend on the hard starts or just doing like a true maximal 3 minute “test” on the first interval and not being able to repeat that… or sometimes a longer rest interval can be the ticket.
Can anyone share just a bit of light on timing for these Vo2 blocks?
I’m considering doing one…but have been doing sweet spot work consistently for a couple months and have been seeing steady progress. I’m not sure I want to rock the boat…but I also hear you shouldnt really do the same thing too long.
generally, you could do a vo2 block after a block of extensive sweet spot or threshold tte work. the goal being vo2 would help increase ftp to do a subsequent threshold tte block
Personally, I’m a big believer in “if it ain’t broke, don’t fix it”. There are exceptions, of course. For example, if you need to do a route with lots of steep, sharp high intensity inclines and all you’re training is SS, that’s not the right plan. But if you’re seeing good gains with what you’re doing and have no reason to intervene, I wouldn’t. I see these kind of blocks as something to do when you’ve plateaued and want to break through a wall.
Hmm. Ok so perhaps now might be a good time. For reference…I’ve worked up from 10 minute intervals to 30 minutes, while bumping power 20 watts, with heart rate actually being lower now during training than when I started.
Yea. The other consideration is that my training will change naturally over the next month or two, with higher volume as the weather gets better, and some intensity from group rides.
personally, if I were working with an athlete, I’d probably get them to do more than 30min intervals for sweet spot before moving on to other work, ideally even something like 1x90
Oh yikes haha!
Yea I havent considered going that long yet. This years experience has made me realize how wildly off my ftp was with TR. 90 minutes at SS does not now strike me as unattainable.
I did 2 x 30 this weekend. I’m sire I could handle 1 x 40…maybe 1 x 60 if i really pushed myself. 90 I’m pretty sure I need to work up to though haha.
The first races I care about are intelligentsia in July…maybe I’ll re-evaluate in late march or april…from what I’ve seen here that should leave enough time to have an impact on mid july fitness.
